- To:
- Subject: Re: [cgal-discuss] Trouble cutting polyhedron using a plane.
- Date: Mon, 26 Oct 2015 05:59:26 -0700 (PDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
- Ironport-phdr: 9a23:X6F+UhQGvCB9wuXp7RvpX0VNJtpsv+yvbD5Q0YIujvd0So/mwa64ZxKN2/xhgRfzUJnB7Loc0qyN4/2mADVLvcvJmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbviptuKOk4U2XKUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGfayQ6NtRrNRCHEqMns++dbwnRjFVwqGoHUGAUsMlR8dDBXD9xH7FsP+ry3htutyxTGGNJzeQrU9WDDk5KBuHky7wBwbPiI0pTmEwvd7i7hW9Uqs
Hi Frederic,
could you share the code/sample snippet using which you are testing the
function and inverting the plane, this is exactly what i want to do as well,
as i've stated in another thread,
(http://cgal-discuss.949826.n4.nabble.com/polyhedron-clipping-using-a-plane-td4661242.html)
and inverting the plane is an essential step for me as well, though i don't
know how to get the other half space except by taking the NOT of the half
space of the plane using nef_polyhedra.
Thanks!
Gunshi
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Trouble-cutting-polyhedron-using-a-plane-tp951826p4661276.html
- Re: [cgal-discuss] Trouble cutting polyhedron using a plane., gunshi, 10/26/2015
