Re: [cgal-discuss] Compilation Error in triangulate_refine_and_fair_hole : CGAL 4.7
- To:
- Subject: Re: [cgal-discuss] Compilation Error in triangulate_refine_and_fair_hole : CGAL 4.7
- Date: Wed, 28 Oct 2015 19:02:01 +0530
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Thanks a lot for the quick reply. But I ma still getting the following error
CGAL/Polygon_mesh_processing/internal/Hole_filling/Weights.h(121): error C2977: 'CGAL::internal::Cotangent_value_Meyer' : too many template arguments
CGAL/internal/Surface_modeling/Weights.h(47) : see declaration of 'CGAL::internal::Cotangent_value_Meyer'
Thanks & Regards,CGAL/Polygon_mesh_processing/internal/Hole_filling/Weights.h(121): error C2977: 'CGAL::internal::Cotangent_value_Meyer' : too many template arguments
On Wed, Oct 28, 2015 at 6:17 PM, Sebastien Loriot (GeometryFactory) <> wrote:
On 10/28/2015 11:57 AM, Harshil Oza wrote:
Windows - VS2013 I have been using.
I have included /CGAL/Polygon_mesh_processing/fair.h to the top but
error is till there.
I meant adding inside CGAL/Polygon_mesh_processing/fair.h
#include <CGAL/Polygon_mesh_processing/internal/Hole_filling/Weights.h>
Anyway, there is an error in naming of preprocessing macros. I fixed in
the release branch.
Here is a copy of the file including the fix:
https://raw.githubusercontent.com/CGAL/cgal/master/Polygon_mesh_processing/include/CGAL/Polygon_mesh_processing/internal/Hole_filling/Weights.h
Sebastien.
Is there and Pr-processor macro that need to set?
Thanks & Regards,
Harshil
On Wed, Oct 28, 2015 at 4:21 PM, Sebastien Loriot (GeometryFactory)
< <mailto:>> wrote:
What platform are you on?
Could you try adding at the top of
include/CGAL/Polygon_mesh_processing/fair.h
#include <CGAL/Polygon_mesh_processing/internal/Hole_filling/Weights.h>?
Thanks,
Sebastien.
On 10/28/2015 11:43 AM, Harshil Oza wrote:
Hi Guys,
I am using the default example and while compiling the same I
got this
following error
error C2039: 'Cotangent_weight_with_voronoi_area_fairing' : is not a
member of 'CGAL::internal'
Quick help will be appreciated.
Thanks & Regards,
Harshil
- [cgal-discuss] Compilation Error in triangulate_refine_and_fair_hole : CGAL 4.7, Harshil Oza, 10/28/2015
- Re: [cgal-discuss] Compilation Error in triangulate_refine_and_fair_hole : CGAL 4.7, Sebastien Loriot (GeometryFactory), 10/28/2015
- Re: [cgal-discuss] Compilation Error in triangulate_refine_and_fair_hole : CGAL 4.7, Harshil Oza, 10/28/2015
- Re: [cgal-discuss] Compilation Error in triangulate_refine_and_fair_hole : CGAL 4.7, Andreas Fabri, 10/28/2015
