Re: [cgal-discuss] CGAL 4.7 Released, Computational Geometry Algorithms Library
- To:
- Subject: Re: [cgal-discuss] CGAL 4.7 Released, Computational Geometry Algorithms Library
- Date: Thu, 29 Oct 2015 14:10:45 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:QGiAXh3ar1mJLfP2smDT+DRfVm0co7zxezQtwd8ZsegRKvad9pjvdHbS+e9qxAeQG96LtrQd2qGK7ujJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6PyZ3mnLzvs7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Lod8JtLXqz+Oqg5VrdFFy8OMmYv5cStuwOQYxGI4y5WdmwLiBdOH0D/7Rf3V4q58gDVn8469ySdOMDqV6EaUD++6L16CVWg3CMOKiQ09n2RkM12gatGiBmurhg5xJTbNtLGfMFid7/QKItJDVFKWdxcAnRM
Le Wednesday 28 October 2015 17:43:42 abvikram a écrit :
> Thanks Sebastien for the reply.
> I have installed Qt5 packages using the Synaptic package manager on
> Ubuntu15.
> Still showing the same error.
Verify that your did have installed the "development" packages of those Qt5
components. Usually, in package managers, they are separate packages, with
names ending with "-devel" or "-dev".
> Is there any conflict between Qt4 (by default) and Qt5?
> Thanks,
> Abhi
You can have both Qt4 and Qt5, and it should not create problems.
Laurent Rineau, PhD
- [cgal-discuss] CGAL 4.7 Released, Computational Geometry Algorithms Library, Laurent Rineau (CGAL/GeometryFactory), 10/20/2015
- Re: [cgal-discuss] CGAL 4.7 Released, Computational Geometry Algorithms Library, Joachim Reichel, 10/22/2015
- Re: [cgal-discuss] CGAL 4.7 Released, Computational Geometry Algorithms Library, abvikram, 10/28/2015
- Re: [cgal-discuss] CGAL 4.7 Released, Computational Geometry Algorithms Library, Sebastien Loriot (GeometryFactory), 10/28/2015
- Re: [cgal-discuss] CGAL 4.7 Released, Computational Geometry Algorithms Library, abvikram, 10/29/2015
- Re: [cgal-discuss] CGAL 4.7 Released, Computational Geometry Algorithms Library, Laurent Rineau (CGAL/GeometryFactory), 10/29/2015
- Re: [cgal-discuss] CGAL 4.7 Released, Computational Geometry Algorithms Library, abvikram, 10/30/2015
