cgal-discuss - Re: [cgal-discuss] How to do 3D constrained Delaunay triangulation using CGAL
  • To:
  • Subject: Re: [cgal-discuss] How to do 3D constrained Delaunay triangulation using CGAL
  • Date: Thu, 29 Oct 2015 14:19:28 -0700
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:wfQtbRyKIcZwT6HXCy+O+j09IxM/srCxBDY+r6Qd0eITIJqq85mqBkHD//Il1AaPBtWGrasVwLOK7ujJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6PyZ3mnLnuptX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86FpyshbTK+vf7gkVacKS3M9ImUt7YvqswPCRE2B/DwHQ2AOm11JBQbCqxr1V5O0virhvfdmw3qmOpj9QrkwHDij9Kx2UwTAiSEdNjd//nuEpNZ3ifejWOrp8xZixo/Sb5iUKdJxe6rceZURQm8XDZUZbDBIHo7pN9hHNOEGJ+sN94Q=
Thank you for the reminder @ Benjamin
I have noticed that Tetgen uses the exact predicates. And I have tried
to switch the default Shewchuk's predicates to CGAL's kernel.
However, the Tetgen package is still using floating-point airthmetic
and represent the coordinates of points using "double". The Steiner
points are constructed inexactly using floating point numbers. I am
trying to find a package that can construct Steiner points in an exact
form.
Anyway, thanks for your kind reminder.
ps: Acturally, switching the predicate kernel in CGAL is pretty easy
but I don't think that is necessary, because the default adaptive
exact predicates works pretty well.
Best
Yinhe
2015-10-29 13:05 GMT-07:00 Benjamin Kehlet
> On 29 October 2015 at 17:45, 郑银河
> wrote:
>> Thank you for the reminder @ Olivier Devillers.
>> I find a package called Tetgen on the web, which can generate the CDT
>> by adding extra points.
>> However, that package is implemented using float point number
>> arithmetic. I am trying to reimplement that package using the exact
>> arithmetic interface provided in CGAL
> Just in case you have overlooked it: Tetgen uses robust predicates. By
> default it is Shewchuk's predicates, but it can also use CGAL's EPICK
> kernel. See
> http://wias-berlin.de/software/tetgen/1.5/doc/manual/manual004.html#sec25
> The relevant section is 3.1.4.
> (Note that I haven't tried this myself)
> Best regards
> Benjamin Kehlet
>> 2015-10-29 1:11 GMT-07:00 Olivier Devillers
>> > Le 29/10/15 04:17, 郑银河 a écrit :
>> > Thanks for your kind replies.
>> > Finally, I am planning to implement this feature by my self to solve my
>> > problem.
>> > A constrained DT does not always exist in 3D
>> > (there exists polyhedra that cannot be triangulated using the prescribed
>> > edges (or faces)
>> > without adding new vertices [ Schönhardt polyhedron] ).
>> You are currently subscribed to cgal-discuss.
>> To unsubscribe or access the archives, go to
>> https://sympa.inria.fr/sympa/info/cgal-discuss
