- To:
- Subject: Re: [cgal-discuss] Segment round incorrectly rejects hot pixel
- Date: Wed, 04 Nov 2015 09:19:17 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:eW7G5BybLFLB9GvXCy+O+j09IxM/srCxBDY+r6Qd0ewQIJqq85mqBkHD//Il1AaPBtWGragVwLOP4+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6PyZ7mnLnrq9X6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqrze+E0TKdTES89G2Ez/szi8xfZHiWV4X5JGF4bmBNTHwnI6lneWY3wtTey9sVw3yyXIdfnY7k/RTO4/uYhAEvzjCAdNjkltmTTosN1haNf5hmmokoskMbvfIiJOa8mLevmdtQASD8ZUw==
Try replacing the CGAL header with the one attached, that should solve your problem. I'll make a PR to integate it in the release.
Sebastien.
On 10/29/2015 08:50 AM, Steven wrote:
Please find the sample code below.
The pixel size is set to 50, whereas the line is obviously much longer than
that, so the result of the snap rounding should simply contain two points.
However, it contains only one. From what I've been able to debug, it seems
that there is no intersection found between one of the hot pixels and the
segment. I don't know the root cause of this though.
Note that if you set the pixel size to for example 1 or 60, it does give the
correct output.
Can anyone confirm this is a bug?
typedef CGAL::Exact_predicates_exact_constructions_kernel K;
typedef CGAL::Snap_rounding_traits_2<K>
Traits;
typedef K::Point_2
Point;
typedef CGAL::Arr_segment_traits_2<K>
SegmentTraits;
typedef SegmentTraits::X_monotone_curve_2
Segment;
typedef std::list<Point>
Polyline;
typedef std::list<Polyline>
Polyline_list;
int main(int argc, char* argv[])
std::list<Segment> seg_list;
seg_list.push_back(Segment(Point(-53700, 28899.999999999996),
Point(-54551.560900716613, 15250.102354145352)));
Polyline_list output_list;
CGAL::snap_rounding_2<Traits, std::list<Segment>::const_iterator,
Polyline_list>
(seg_list.begin(), seg_list.end(), output_list, 50, false,
false, 1);
assert (output_list.size() == 1);
assert (output_list.front().size() == 2);
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Segment-round-incorrectly-rejects-hot-pixel-tp4661300.html
// Copyright (c) 2001,2009,2014 Tel-Aviv University (Israel), Max-Planck-Institute Saarbruecken (Germany). // All rights reserved. // // This file is part of CGAL (www.cgal.org). // You can redistribute it and/or modify it under the terms of the GNU // General Public License as published by the Free Software Foundation, // either version 3 of the License, or (at your option) any later version. // // Licensees holding a valid commercial license may use this file in // accordance with the commercial license agreement provided with the software. // // This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE // WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. // // $URL$ // $Id$ // // // author(s) : Eli Packer <>, // Waqar Khan <> #ifndef CGAL_SNAP_ROUNDING_2_TRAITS_H #define CGAL_SNAP_ROUNDING_2_TRAITS_H #include <CGAL/basic.h> #include <map> #include <list> #include <CGAL/Arr_segment_traits_2.h> namespace CGAL { template<class Base_kernel> class Snap_rounding_traits_2 : public CGAL::Arr_segment_traits_2<Base_kernel> { public: // otherwise Segment_data cannot access the types typedef typename Base_kernel::FT NT; typedef typename Base_kernel::FT FT; typedef typename Base_kernel::Point_2 Point_2; typedef typename Base_kernel::Segment_2 Segment_2; typedef typename Base_kernel::Iso_rectangle_2 Iso_rectangle_2; typedef typename Base_kernel::Vector_2 Vector_2; typedef typename Base_kernel::Line_2 Line_2; typedef typename Base_kernel::Aff_transformation_2 Aff_transformation_2; typedef typename Base_kernel::Direction_2 Direction_2; typedef typename Base_kernel::Construct_vertex_2 Construct_vertex_2 ; typedef typename Base_kernel::Construct_segment_2 Construct_segment_2 ; typedef typename Base_kernel::Construct_iso_rectangle_2 Construct_iso_rectangle_2; typedef typename Base_kernel::Compare_y_2 Compare_y_2; typedef typename Base_kernel::Construct_min_vertex_2 Construct_min_vertex_2; typedef typename Base_kernel::Construct_max_vertex_2 Construct_max_vertex_2; typedef typename Base_kernel::Cartesian_const_iterator_2 Cartesian_const_iterator_2; typedef typename Base_kernel::Construct_cartesian_const_iterator_2 Construct_cartesian_const_iterator_2; typedef CGAL::Arr_segment_traits_2<Base_kernel> Base_traits; typedef typename Base_traits::Compare_x_2 Compare_x_2; typedef CGAL::To_double<NT> To_double; public: /*! Functor */ class Snap_2 { public: void operator()(const Point_2& p, NT pixel_size, NT &x, NT &y) { NT x_tmp = p.x() / pixel_size; NT y_tmp = p.y() / pixel_size; double x_floor = std::floor(CGAL::to_double(x_tmp)); double y_floor = std::floor(CGAL::to_double(y_tmp)); while(x_floor>x_tmp) x_floor-=1; while(y_floor>y_tmp) y_floor-=1; CGAL_assertion(x_floor<=x_tmp); CGAL_assertion(y_floor<=y_tmp); x = NT(x_floor) * pixel_size + pixel_size / NT(2.0); y = NT(y_floor) * pixel_size + pixel_size / NT(2.0); } }; Snap_2 snap_2_object() const { return Snap_2(); } /*! Functor */ class Integer_grid_point_2 { public: Point_2 operator()(const Point_2& p, NT pixel_size) { NT x = (p.x() - pixel_size / NT(2.0)) / pixel_size; NT y = (p.y() - pixel_size / NT(2.0)) / pixel_size; Point_2 out_p(x,y); return(out_p); } }; /*! */ Integer_grid_point_2 integer_grid_point_2_object() const { return Integer_grid_point_2(); } /*! Functor */ class Minkowski_sum_with_pixel_2 { private: typedef Snap_rounding_traits_2<Base_kernel> Traits; typedef std::list<Point_2> Point_list; const Traits * m_gt; Minkowski_sum_with_pixel_2(const Traits * gt) : m_gt(gt) {} public: void operator()(Point_list & points_list, const Segment_2& s, NT unit_square) { Construct_vertex_2 construct_ver = m_gt->construct_vertex_2_object(); Compare_y_2 compare_y = m_gt->compare_y_2_object(); Compare_x_2 compare_x = m_gt->compare_x_2_object(); Point_2 src = construct_ver(s, 0); Point_2 trg = construct_ver(s, 1); Comparison_result cx = compare_x(src, trg); Comparison_result cy = compare_y(src, trg); NT x1 = src.x(); NT y1 = src.y(); NT x2 = trg.x(); NT y2 = trg.y(); Point_2 ms1, ms2, ms3, ms4, ms5, ms6;// minkowski sum points if (cx == SMALLER) { if (cy == SMALLER) { // we use unit_square instead of unit_square / 2 in order to // find tangency points which are not supported by kd-tree ms1 = Point_2(x1 - unit_square, y1 - unit_square); ms2 = Point_2(x1 - unit_square, y1 + unit_square); ms3 = Point_2(x1 + unit_square, y1 - unit_square); ms4 = Point_2(x2 + unit_square, y2 - unit_square); ms5 = Point_2(x2 + unit_square, y2 + unit_square); ms6 = Point_2(x2 - unit_square, y2 + unit_square); } else { ms1 = Point_2(x1 - unit_square, y1 - unit_square); ms2 = Point_2(x1 - unit_square, y1 + unit_square); ms3 = Point_2(x1 + unit_square, y1 + unit_square); ms4 = Point_2(x2 + unit_square, y2 - unit_square); ms5 = Point_2(x2 + unit_square, y2 + unit_square); ms6 = Point_2(x2 - unit_square, y2 - unit_square); } } else { if(cy == SMALLER) { ms1 = Point_2(x1 + unit_square, y1 - unit_square); ms2 = Point_2(x1 + unit_square, y1 + unit_square); ms3 = Point_2(x1 - unit_square, y1 - unit_square); ms4 = Point_2(x2 + unit_square, y2 + unit_square); ms5 = Point_2(x2 - unit_square, y2 + unit_square); ms6 = Point_2(x2 - unit_square, y2 - unit_square); } else { ms1 = Point_2(x1 + unit_square, y1 - unit_square); ms2 = Point_2(x1 + unit_square, y1 + unit_square); ms3 = Point_2(x1 - unit_square, y1 + unit_square); ms4 = Point_2(x2 + unit_square, y2 - unit_square); ms5 = Point_2(x2 - unit_square, y2 - unit_square); ms6 = Point_2(x2 - unit_square, y2 + unit_square); } } points_list.push_back(ms1); points_list.push_back(ms2); points_list.push_back(ms3); points_list.push_back(ms4); points_list.push_back(ms5); points_list.push_back(ms6); } friend class Snap_rounding_traits_2<Base_kernel>; }; /*! */ Minkowski_sum_with_pixel_2 minkowski_sum_with_pixel_2_object() const { return Minkowski_sum_with_pixel_2(this); } Construct_segment_2 construct_segment_2_object() const { Base_kernel k; return k.construct_segment_2_object(); } Construct_vertex_2 construct_vertex_2_object() const { Base_kernel k; return k.construct_vertex_2_object(); } Compare_y_2 compare_y_2_object() const { Base_kernel k; return k.compare_y_2_object(); } Construct_iso_rectangle_2 construct_iso_rectangle_2_object() const { Base_kernel k; return k.construct_iso_rectangle_2_object(); } }; } //namespace CGAL #endif // CGAL_ISR_2_TRAITS_H
- Re: [cgal-discuss] Segment round incorrectly rejects hot pixel, Sebastien Loriot (GeometryFactory), 11/04/2015
