- To:
- Subject: [cgal-discuss] Nef_polyhedron_3 compilation error
- Date: Fri, 6 Nov 2015 07:10:11 -0800 (PST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
- Ironport-phdr: 9a23:QvhywR+IKLzdqP9uRHKM819IXTAuvvDOBiVQ1KB91+8cTK2v8tzYMVDF4r011RmSDdids6oMotGVmp6jcFRI2YyGvnEGfc4EfD4+ouJSoTYdBtWYA1bwNv/gYn9yNs1DUFh44yPzahANS47AblHf6ke/8SQVUk2mc1Ele6KtQsb7tIee6aObw9XreQJGhT6wM/tZDS6dikHvjPQQmpZoMa0ryxHE8TNicuVSwn50dxrIx06vrvGZp8Aytn0I87J6r5YBAu3GePEzQrVcSTgnKGso/9bDtB/ZTALJ6GFPfH8Rl09NGT/F4RX+FsP8tDX3sO14niafFcLzRLEwHz+l6vE4G1fTlC4bOmtgoynsgctqgfcA+Eqs
Hello.
I have problems compiling simple example
using namespace CGAL;
typedef Exact_predicates_exact_constructions_kernel K1;
typedef Nef_polyhedron_3<K1> Nef_polyhedron;
typedef Polyhedron_3<K1> Polyhedron;
typedef Polyhedron::HalfedgeDS HalfedgeDS;
typedef Polyhedron::Halfedge_handle Halfedge_handle;
typedef Polyhedron::Halfedge_iterator Halfedge_iterator;
void test()
Nef_polyhedron N;
When compiling I've got this error:
f:\development\zbuilder1\3rdparty\cgal\include\cgal\nef_2\segment_overlay_traits.h(1042):
error C4703: potentially uninitialized local pointer variable 'next_seg'
used
using another kernel
typedef CGAL::Exact_integer NT;
typedef CGAL::Homogeneous<NT> K2;
gives the same error.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Nef-polyhedron-3-compilation-error-tp4661322.html
- [cgal-discuss] Nef_polyhedron_3 compilation error, mr_hell, 11/06/2015
