- To:
- Subject: [cgal-discuss] Extending Polyhedron faces do not compile.
- Date: Tue, 10 Nov 2015 06:04:15 -0800 (PST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:hsrCkBZtpoeiIoSMTmXvPbz/LSx+4OfEezUN459isYplN5qZpcizbnLW6fgltlLVR4KTs6sC0LqL9fy9EjFeqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh730p8CYPlsArQH+SI0xBS3+lR/WuMgSjNkqAYcK4TyNnEF1ff9Lz3hjP1OZkkW0zM6x+Jl+73YY4Kp5pIZ2eP6kLuFhFfQYV2x+cjN92Mq+vhbKSU6D52AXT34NuhtOGQnMqh/gDbnrtS6vmet53CSBdZn1S70pQi/k4I93TwXujzxBPDk8pjKEwvdshb5W9Uvy7yd0xJTZNdrNbPc=
Hello,
I'm trying to extend Faces in Polyhedron, I get compilation error :
Error :
C:\MyProjects\projet_dll\CGAL-4.5\include\CGAL\Nef_3\polyhedron_3_to_nef_3.h:265:
erreur : incomplete type
'CGAL::internal::Plane_constructor<CGAL::HalfedgeDS_face_base<CGAL::HalfedgeDS_list_types<CGAL::Epeck,
CGAL::I_Polyhedron_derived_items_3<My_items>, std::allocator<int> >,
CGAL::Boolean_tag<true>, CGAL::Boolean_tag<false> >::Plane_not_supported>'
used in nested name specifier
internal::Plane_constructor<Plane>::get_opposite_orthogonal_vector(pe_prev->facet()->plane()));
Code (*.h) :
#ifndef POLYHEDRON_AC_H
#define POLYHEDRON_AC_H
#include "formvirtual.h"
#include "polygon_ac.h"
#include <CGAL/Exact_predicates_exact_constructions_kernel.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/IO/Polyhedron_iostream.h>
#include <CGAL/IO/Nef_polyhedron_iostream_3.h>
#include <CGAL/Bbox_3.h>
#include <CGAL/bounding_box.h>
#include <iostream>
#include <fstream>
// A face type with a color member variable.
template <class Refs>
struct My_face : public CGAL::HalfedgeDS_face_base<Refs> {
CGAL::Color color;
// An items type using my face.
struct My_items : public CGAL::Polyhedron_items_3 {
template <class Refs, class Traits>
struct Face_wrapper {
typedef My_face<Refs> Face;
typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;
*typedef CGAL::Polyhedron_3<Kernel, My_items> Polyhedron; // **** HERE
typedef Polyhedron::Halfedge_handle Halfedge_handle;
typedef Polyhedron::Halfedge_around_facet_const_circulator HF_circulator;
typedef Polyhedron::HalfedgeDS HalfedgeDS;
typedef CGAL::Nef_polyhedron_3<Kernel> Nef_polyhedron;
typedef CGAL::Bbox_3 Bbox_3;
typedef Kernel::Iso_cuboid_3 Iso_cuboid_3;
typedef CGAL::Aff_transformation_3 <Kernel> Transformation_3;
typedef CGAL::Vector_3<Kernel> Vector_ex;
class Polyhedron_ac :public FormVirtual, public Polyhedron
Q_OBJECT
Any clue ?
Gilles
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Extending-Polyhedron-faces-do-not-compile-tp4661326.html
- [cgal-discuss] Extending Polyhedron faces do not compile., Gilles, 11/10/2015
