Re: [cgal-discuss] CGAL 4.7 Released, Computational Geometry Algorithms Library
- To:
- Subject: Re: [cgal-discuss] CGAL 4.7 Released, Computational Geometry Algorithms Library
- Date: Sun, 15 Nov 2015 21:54:58 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:ISdP9Bz0s0yrVeXXCy+O+j09IxM/srCxBDY+r6Qd0e4RIJqq85mqBkHD//Il1AaPBtWGra8ZwLON6ejJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6PyZnqnLnpodX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqrze+E0TKdTES89G2Ez/szi8xfZHiWV4X5JcGIfmRpJBkD/4RDxXpr1+n/4seN22Cife9f7TLs0VDCK4KJ7DhPl3nRUfwUl+X3a35QjxJlQpwis8kRy
Hi,
On 11/15/2015 04:18 PM, abvikram wrote:
> Hello Joachim,
> for the Debian source it is showing error:
> W: GPG error: http://debian.cgal.org jessie InRelease: The following
> signatures couldn't be verified because the public key is not available:
> NO_PUBKEY_B8FAFF1C43886771
that is my PGP key which is used to sign the packages. You can get it from any
keyserver or from my web page
wget http://joachim-reichel.de/aboutme/pgpkey/0x43886771.asc
and if you trust this key then import it into apt's key chain via
apt-key add 0x43886771.asc
Joachim
- Re: [cgal-discuss] CGAL 4.7 Released, Computational Geometry Algorithms Library, abvikram, 11/15/2015
- Re: [cgal-discuss] CGAL 4.7 Released, Computational Geometry Algorithms Library, Joachim Reichel, 11/15/2015
- Re: [cgal-discuss] CGAL 4.7 Released, Computational Geometry Algorithms Library, abvikram, 11/16/2015
- Re: [cgal-discuss] *** GMX Spamverdacht *** Re: CGAL 4.7 Released, Computational Geometry Algorithms Library, Joachim Reichel, 11/17/2015
