cgal-discuss - [cgal-discuss] use zone() with Arrangement_2
  • To:
  • Subject: [cgal-discuss] use zone() with Arrangement_2
  • Date: Thu, 19 Nov 2015 09:50:12 -0800 (PST)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=PermError ; spf=None
  • Ironport-phdr: 9a23:pYuLVhWzvkrDVDXSKqc0YeS2IKjV8LGtZVwlr6E/grcLSJyIuqrYZhGCt8tkgFKBZ4jH8fUM07OQ6PC9HzJbqs/Z6zgrS99laVwssY0uhQsuAcqIWwXQDcXBSGgEJvlET0Jv5HqhMEJYS47UblzWpWCuv3ZJQk2sfTR8Kum9IIPOlcP/j7n0oM2OJVsTz2PlOvtbF1afk0b4joEum4xsK6I8mFPig0BjXKBo/15uPk+ZhB3m5829r9ZJ+iVUvO89pYYbCf2pN5IRFuIJSW1+eyBuvJWq5lH/Sl6E6XIYF2kXiRFVGBPt7RfgX563vDGpmPB63Xy2NMj3QLYYXim5p/NnQRrphSFBOxYi9mjPic12yqxB9kHy7ydjypLZNdjGfMF1ebnQKIhCHWc=
Hi All,
I try to use zone(arrangement, segment, back_inserter(intersected_objs))
funtion. Here is my code :
/* some includes */
typedef CGAL::Simple_cartesian<double> Kernel;
typedef CGAL::Arr_segment_traits_2<Kernel> Traits_2;
typedef CGAL::Arr_face_extended_dcel<Traits_2, unsigned int> Dcel;
typedef CGAL::Arrangement_2<Traits_2, Dcel> Arrangement_2;
int main()
/* Create arrangement */
CGAL::Arrangement_2<Traits_2, Dcel> arrangement;
insert(arrangement, Segment_2(Point_2(0, 0), Point_2(2, 0)));
insert(arrangement, Segment_2(Point_2(2, 0), Point_2(2, 2)));
insert(arrangement, Segment_2(Point_2(2, 2), Point_2(0, 2)));
insert(arrangement, Segment_2(Point_2(0, 2), Point_2(0, 0)));
/* Create segment */
const size_t segmentNumber = 3;
Segment_2 segments[segmentNumber];
segments[0] = Segment_2(Point_2(-2, -2), Point_2(-1, -1));
segments[1] = Segment_2(Point_2(-1, 1), Point_2(1, 1));
segments[2] = Segment_2(Point_2(0, 0), Point_2(3, 0));
/* Create structure to cast the objects given by zone function */
Arrangement_2::Vertex_const_handle vertex;
Arrangement_2::Halfedge_const_handle edge;
Arrangement_2::Face_const_handle face;
/* Test for each segment which objects it will cross */
for (size_t k = 0; k < segmentNumber; k++)
std::vector<CGAL::Object> intersected_objs;
CGAL::zone(arrangement, segments[k],
std::back_inserter(intersected_objs));
std::cout << "the segment intersects " <<
intersected_objs.size()
<< " objects" << std::endl;
for (size_t i = 0; i < intersected_objs.size(); i++) {
if (CGAL::assign(face, intersected_objs.at(i)))
// segments[k] is located inside a face:
if (face->is_unbounded())
std::cout << "inside the unbounded
face." << std::endl;
else
std::cout << "inside a bounded
else if (CGAL::assign(edge, intersected_objs.at(i)))
// segments[k] is located on an edge:
std::cout << "on an edge: " << edge->curve()
<< std::endl;
else if (CGAL::assign(vertex,
// segments[k] is located on a vertex:
if (vertex->is_isolated())
std::cout << "on an isolated vertex:
" << vertex->point() << std::endl;
else
std::cout << "on a vertex: " <<
else
std::cout << "invalid object " << std::endl;
Right now I assume the return of zone function could be
Arrangement_2::Vertex_const_handle, Halfedge_const_handle,
Face_const_handle. I do get non-empty intersected object list (and the
number of intersected objects is correct), but when I try to object_cast its
elements to Vertex/Halfedge/Face, I only get NULL pointer values. The
documentation of zone() doesn't give a list of possible return type. What is
the right way to use this function?
Thanks a lot,
Damien
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/use-zone-with-Arrangement-2-tp4661363.html
