cgal-discuss - Re: [cgal-discuss] How to visualize '.cgal' file
  • To:
  • Subject: Re: [cgal-discuss] How to visualize '.cgal' file
  • Date: Sun, 29 Nov 2015 12:05:04 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:oZd2ARWMPcyRzkDd8KN6BDA0C13V8LGtZVwlr6E/grcLSJyIuqrYZhGGt8tkgFKBZ4jH8fUM07OQ6PC9Hzxeqsza+Fk5M7VyFDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3CwN5K6zPF5LIiIzvjqbpq8CVM1sD3mH1SIgxBSv1hD2ZjtMRj4pmJ/R54TryiVwMRd5rw3h1L0mYhRf265T41pdi9yNNp6BprJYYAu2pN5g/GLdXBTBjP2Eu79DwrjHCSxGO7z0SSDY4iB1NVjDC6CbfWZHqKRzCq/BhXR66MMn3SLksEWC66KMtTRjukyAvNzM98WTekop7jPQI81qauxVjztuMM8muP/1kc/aFcA==
What is contents​' format of the file?
Maybe this question I asked a week ago helps you:
http://stackoverflow.com/questions/33889617/get-a-mesh-3-off-from-projection-traits-xy-3-constrained-delaunay/33933853#33933853
The actual code version is under revision but I can send it to you if it helps.
Essentially we write the off by hand, it ain't a complicated format.
Cheers,
Pol
