cgal-discuss - [cgal-discuss] Affected faces after boolean operation (difference).
  • To:
  • Subject: [cgal-discuss] Affected faces after boolean operation (difference).
  • Date: Tue, 1 Dec 2015 04:19:56 -0800 (PST)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23:7PCxdhVzeP1zHYaypOSM0/A5SA/V8LGtZVwlr6E/grcLSJyIuqrYZhCOt8tkgFKBZ4jH8fUM07OQ6PC+HzRYqs/d+Fk5M7VyFDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3CwN5K6zPF5LIiIzvjqbpq8OVO10D3Wb1SIgxBSv1hD2ZjtMRj4pmJ/R54TryiVwMRd5rw3h1L0mYhRf265T41pdi9yNNp6BprJYYAu3MVv9mHPkBVHxmaDhtpZ6jiR6WRgSG4j4QU34djwFTKwnD9hDzGJnr4QXgse8o9yieOcDtBeQ3Xzm/9LwtRzf0jz0BMCV/+2bS3J8jxJlHqQ6s8kUsi7XfZ5uYYaEmJq4=
Hello,
Well, it's not a purely question about CGAL, but...
I would like to know the new created faces after a boolean operation
(difference). As I'm developping a machining simulation software.
-> Here two polyhedrons A and B :
<http://cgal-discuss.949826.n4.nabble.com/file/n4661425/a_eats_b.png>
As A 'eats' B, I would like to distinguish the affected face as you can see
here, in red :
<http://cgal-discuss.949826.n4.nabble.com/file/n4661425/after.png>
I firstly though to find the common plane équations of faces between A and
B, just after the boolean op.
*Is it a good way to do it or do you have another better idea ???
(A and B will have a few hundreds of faces each)*
Thanks for help.
Gilles
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Affected-faces-after-boolean-operation-difference-tp4661425.html
