Re: [cgal-discuss] What's the difference between the "face" and "facet" in Class TriangulationDataStructure
- To:
- Subject: Re: [cgal-discuss] What's the difference between the "face" and "facet" in Class TriangulationDataStructure
- Date: Wed, 2 Dec 2015 09:57:47 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:JiUrwhxTiYc6EoLXCy+O+j09IxM/srCxBDY+r6Qd0eMTIJqq85mqBkHD//Il1AaPBtWFraocw8Pt8IneGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2WVTerzWI4CIIHV2nbEwudrqzQtaapv/0/t7x0qWbWx9Piju5bOE6BzSNhiKViPMrh5B/IL060BrDrygAUe1XwWR1OQDbxE6ktY/jtKNl6Dla7vI969ZbA+K9ZLU9VbUeDTI8Mmlz6tesrgjGVQLI530SVSIdnRNMRgTE9xrnRYyijiyvveV03GyWPNb9UKsvcTWk9aZiDhHy2wkdMDts22VWj8F2kJV5qRegoVQryIrZZYyTKLx8d6bce5UCX21pUcNYVigHCYS5OdhcR9EdNPpV+tGu72AFqgGzUFGh
Hi,
On Wed, Nov 25, 2015 at 6:41 PM, BRYang <> wrote:
In which dimension are you? Because you seem to use the dD trangulation package, but if you are in dimension 3, you should use the 3D triangulation package.
Hi, everyone.
I have a Delaunay Triangulation, say DT. The points used for the Delaunay
Triangulation are the vertices of a triangle mesh T. And I would like to get
all the tetrahedrons of DT which are incident to a face S of the triangle
mesh. Any idea of doing that?
And I am still confused about the definitions of "face" and "facet" in
Class TriangulationDataStructure. The "facet " means the faces of the
tetrahedrons or the faces of the triangle mesh?
Face and facets are defined here: http://doc.cgal.org/latest/Triangulation/#title3
Best,
Clément
View this message in context: http://cgal-discuss.949826.n4.nabble.com/What-s-the-difference-between-the-face-and-facet-in-Class-TriangulationDataStructure-tp4661397.html
- Re: [cgal-discuss] What's the difference between the "face" and "facet" in Class TriangulationDataStructure, Clément Jamin, 12/02/2015
