- To:
- Subject: [cgal-discuss] Merging surface meshes and retaining region/face IDs
- Date: Tue, 15 Dec 2015 08:44:12 -0800 (PST)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
- Ironport-phdr: 9a23:De6VPxKxtZT+SkwkudmcpTZWNBhigK39O0sv0rFitYgULv/xwZ3uMQTl6Ol3ixeRBMOAu6wC07KempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXsq3G/pQQfBg/4fVIsYL+lRMiK14ye7KObxd76W01wnj2zYLd/fl2djD76kY0ou7ZkMbs70RDTo3FFKKx8zGJsIk+PzV6nvp/jtKhKqHoB/qt5v44bCf27LOwESulTAz0idmw0/8b2rgLrTA2V53JaXH9FvABPBl3A8BiiDpHr+n//quMliC+AFdb2QL5yUD/k8qQ9G0ygszsOKzNsqTKfscd3lq8O+0r5qg==
Hi,
Is there a way to merge two surfaces (using the union boolean operator for
example) and retain facet/triangle IDs for the merged geometry such that you
can differentiate between the original two surface mesh triangles in the
merged geometry? I am able to generate a merged geometry using the union
operation however, not sure how the surface IDs can be stored in the initial
surfaces and consequently be propagated to the merged geometry. Essentially
I want the output to be a single surface mesh with two distinct IDs assigned
to triangles belonging to shape 1 and 2 (used to generate the merged
geometry). Does anyone have a solution for this? Any help would be much
appreciated!
Best regards,
Nishant Ravikumar
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Merging-surface-meshes-and-retaining-region-face-IDs-tp4661464.html
- [cgal-discuss] Merging surface meshes and retaining region/face IDs, mta08nr, 12/15/2015
