- To:
- Subject: [cgal-discuss] intersect and join to meshes
- Date: Tue, 12 Jan 2016 22:55:32 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:nWZYTxSMRi1a2iFoplo2Ve2NSdpsv+yvbD5Q0YIujvd0So/mwa64YByN2/xhgRfzUJnB7Loc0qyN4/6mCTFLvsbJmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbvipduDPk4X1HKUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGfayQ6NtRrNRCHEqMns++dbwnRjFVwqGoHUGAUsMlR8dIRXB7RiycJbquSv3rKIp2jSePMSwUKw5Hzqj9KxrRQXAhyIONjp/+2bS3J8jxJlHqQ6s8kQsi7XfZ5uYYaJz
I am new to CGAL and I hope you can help me with some pointers.
I have two surfaces made of triangular elements. For simplicity , one surface is a disk like a CD without the hole. The other surface is a cylinder also defined by triangles (I am not talking about solid element , but about 3d surfaces defined by triangles).
Now the disk cuts the cylinder, for simplicity , in the middle of the cross section. As a result I have two cylinders each with the half of the length of the original cylinder. lets say one cylinder above and the other cylinder below the disk.
I want to delete one cylinder , above the disk for example. Of course, as a result of the intersection my disk will have a hole , like a CD. Finally I would like to join the remaining cylinder with the disk , the final surface looks like a sink. This surface muss be defined by triangular elements.
Cheers
Julia
- [cgal-discuss] intersect and join to meshes, Julia Fischer, 01/12/2016
