cgal-discuss - Re: [cgal-discuss] Finding inner vertices in mesh_optimization_lloyd_example
  • To:
  • Subject: Re: [cgal-discuss] Finding inner vertices in mesh_optimization_lloyd_example
  • Date: Wed, 27 Jan 2016 13:07:22 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23:dzt6mBcnh+oOMAcMGVlefbdFlGMj4u6mDksu8pMizoh2WeGdxc6/YB7h7PlgxGXEQZ/co6odzbGG7Oa4AydbuN6oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDtvcWJKF4RzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IAu3GePEzQrVcSTgnKGso/9bDtB/ZTALJ6GFPfH8Rl09hBQTf4RjhFrn4uDH7/r503iWAMMTtC749Uy6jx6hmTxrllD0WOTcy7GbNm4p7i6cN80HpnAB234OBONLdD/F5ZK6IJd4=
Hello,
I've rewritten the program you posted and I've put it on github:
https://gist.github.com/afabri/32a7b4082208bd53b78d
I did not really try to understand your program,
so let me just make some remarks:
Note that when you have a cavity the infinite vertex is
not a vertex of a cell.
Also never create or copy a Cell, only use Cell_handle
or Cell_iterator and access data with ->
You cannot fully control the number of inner vertices,
as the mesh generator will in any case Delaunay tetrahedra.
There are less vertices if you do not set the
cell_radius_edge_ratio
Best,
Andreas
On 26/01/2016 14:36, Pierre Hallot wrote:
Hello,
I have a few questions on the mesh_optimization_lloyd_example that can
be found in cgal/Mesh_3/examples/Mesh_3/mesh_optimization_lloyd_example.
I am currently using the provided example (liver.inr.gz) and just trying
to interact with the results.
First, I am trying to find the points that are inside the created mesh,
and to differentiate them from those that are on the boundary.
From what I've read, I can find them based on the fact that a vertex on
the boundary will have one adjacent vertex which is infinite.
I thus made the following code that I added at the end of the file
without modifying anything else:
Tr t = c3t3.triangulation();
// sets so that the same points are not added twice
std::set<C3t3::Vertex_handle> innerVertices;
std::set<C3t3::Vertex_handle> outerVertices;
for (C3t3::Cells_in_complex_iterator cell =
c3t3.cells_in_complex_begin(), end = c3t3.cells_in_complex_end(); cell
!= end; ++cell)
const Tr::Cell c(*cell);
// each tetrahedra has 4 vertices
for (int i = 0; i < 4; ++i)
// the vertices connected to the one we are checking
std::vector<C3t3::Vertex_handle> adjacent_vertices;
t.adjacent_vertices(c.vertex(i),
std::back_inserter(adjacent_vertices));
bool onBoundary = false;
int counter = 0;
for (std::vector<C3t3::Vertex_handle>::iterator it =
adjacent_vertices.begin(); it != adjacent_vertices.end(); ++it)
if (t.is_infinite(adjacent_vertices.at(counter)))
onBoundary = true;
break;
++counter;
if (!onBoundary)
innerVertices.insert(c.vertex(i));
else
outerVertices.insert(c.vertex(i));
std::cout << "CountInner: " << innerVertices.size() << std::endl;
std::cout << "CountOuter: " << outerVertices.size() << std::endl;
However, no vertex seems to be infinite and thus every point is
considered as inside the complex. How is it possible?
Related to this, the File_medit.h outputs a dimension in the .mesh file
(the fourth parameter).
I think I read somewhere that 3 means it is inside the complex while 2
is on the boundary.
That's exactly what I need, however for the liver, there are about 2000
vertices (out of a total of 3361) with dimension 3 and less than a
thousand with dimension 2, the rest has a dimension of 1, 0 or -1.
I would have expected to have much more vertices on the boundary than
inside the complex however, is what I am saying correct?
Moreover, if I replace the liver.inr.gz file by my own .inr file,
everything has a dimension of 1, which makes this method useless.
Lastly, is it possible to fix the number of vertices inside the complex
that will be created during the make_mesh_3 call? For instance, I would
like to have only 256 vertices inside. (I don't care about the number on
the boundary.)
Kind regards,
Pierre Hallot
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
