- To:
- Subject: Re: [cgal-discuss] travessing order vertices arrangement
- Date: Sat, 30 Jan 2016 18:06:47 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:eRAHRhV/DEb2ZyY7JtXBKnbhUX/V8LGtZVwlr6E/grcLSJyIuqrYZheCt8tkgFKBZ4jH8fUM07OQ6PC/HzRQqsba+Fk5M7VyFDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3CwN5K6zPF5LIiIzvjqbpq8KVO1UD1GH1SIgxBSv1hD2ZjtMRj4pmJ/R54TryiVwMRd5rw3h1L0mYhRf265T41pdi9yNNp6BprJYYAu2pN5g/GLdXBTBjP2Eu79DwrjHCSxGO7z0SSDY4iB1NViXL7VnUWZj8tmOuu+R81i6VMMneQrU9WDDk5KBuHky7wBwbPiI0pTmEwvd7i7hW9Uqs
You can obtain the creation order by extending the vertex record with a field of an unsigned integer type, e.g. size_t, and using an observer class to initialize this field when the vertex is created.
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
_/
On Sat, Jan 30, 2016 at 1:59 PM, Mateus Bellomo <> wrote:
I thought about creating order...2016-01-30 6:53 GMT-02:00 Efi Fogel <>:There is none.
What specific order could there be?____ _ ____ _
_/On Fri, Jan 29, 2016 at 10:28 PM, Mateus Bellomo <> wrote:MateusThanksHi,I would like to know if there is a specific order when traversing vertices (and also faces) from Arrangement_2 using the .vertices_begin() iterator (and .faces_begin() iterator). I searched this info in the manual but I did not find it.
- [cgal-discuss] travessing order vertices arrangement, Mateus Bellomo, 01/29/2016
- Re: [cgal-discuss] travessing order vertices arrangement, Efi Fogel, 01/30/2016
- Re: [cgal-discuss] travessing order vertices arrangement, Mateus Bellomo, 01/30/2016
