- To:
- Subject: [cgal-discuss] How to convert git clone into tarball? They are different
- Date: Mon, 1 Feb 2016 10:01:32 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:B646Lhcj9f1Xj2/b4gGOl8NplGMj4u6mDksu8pMizoh2WeGdxc6+Yh7h7PlgxGXEQZ/co6odzbGG7Oa5ACdYsN6oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDtvcSKKF0ZzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IAu3GePEzQrVcSTgnKGso/9bDtB/ZTALJ6GFPfH8Rl09qBAjDpDHzRIn8o2OutO193m+aNNfoQKEcUi6/6axrWRPhlC5BPDk8pjKEwvdshb5W9Ury7yd0xJTZNdmY
Hello all,
If I want to look at CGAL 4.7 source code, I can do the following:
1) git clone https://github.com/CGAL/cgal.git
2) cd cgal
3) git checkout releases/CGAL-4.7
When I do this, I see over 100 subdirectories.
Next, I take a look at the CGAL-4.7 release tarball found here:
I see that the directory structure is very different. The manual (http://doc.cgal.org/latest/Manual/installation.html) does seem to indicate that this is expected. However, I could not find where it explains how the tarball is made from the original git source code.
Is that something that somebody could explain to me?
Best regards,
-John
- [cgal-discuss] How to convert git clone into tarball? They are different, John Harvey, 02/01/2016
- Re: [cgal-discuss] How to convert git clone into tarball? They are different, Adam Getchell, 02/01/2016
- Re: [cgal-discuss] How to convert git clone into tarball? They are different, Sebastien Loriot (GeometryFactory), 02/04/2016
