cgal-discuss - [cgal-discuss] Changing not isolated vertex position
  • To:
  • Subject: [cgal-discuss] Changing not isolated vertex position
  • Date: Wed, 3 Feb 2016 18:13:37 -0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:knyWfhfYG/lWtJ+hJ1rLu/DmlGMj4u6mDksu8pMizoh2WeGdxc6+Yx7h7PlgxGXEQZ/co6odzbGG7Oa5BydZucnJmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbvipNuKPU4R3GX1SIgxBSv1hD2ZjtMRj4pmJ/R54TryiVwMRd5rw3h1L0mYhRf265T41pdi9yNNp6BprJYYAu2pN5g/GLdXBTBjP2Eu79DwrjHCSxGO7z0SSDY4iB1NVi3M8BznRd/bvy/+se96kH2fNNH7UKs+VDCm6KJsYBDtgSYDcTU+9TeE2YRLkKtHrUf59FREyInObdTNOQ==
Hello all,
I have a quadrilateral grid as an Arrangement_2. I'm making some operations in it as moving some vertices with degree 4. To make this operations I'm removing the four edges incident to a vertex v, change the v position and putting back the edges in v with its neighbours. After this operations I want to iterate over the arrangement faces in a certain order, as I defined in the beginning extending DCEL faces and attributing an index. I noticed that my face indices are becoming 0 after the moving operations and I think it's right since I'm merging 4 faces into 1 and then splitting this face in another 4.
I'm wondering if there is a way to move a vertex with degree 4 without changing the four faces adjacent to it.
Thanks
Mateus
