- To: cgal-discuss <>
- Subject: [cgal-discuss] Memory leak when using Polyhedron_3<EPECK>
- Date: Wed, 17 Feb 2016 02:17:29 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:Cs2BrBeEK5FGLaeM5I5ibE2wlGMj4u6mDksu8pMizoh2WeGdxc6/Yh7h7PlgxGXEQZ/co6odzbGG7Oa8BSdbvd6oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDtvcGPKF4UzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IAu3GePEzQrVcSTgnKGso/9aj4RLMRA/K6noHWXgNiTJJBRLE5Vf0RMGinDH9s79X1S+YNMj3S/gXVDSm4rsjHBXljiUOMj862HrWj9F0heRdp0Ty9FRE34fIbdTNZ7JFdaTHcIZCSA==
Dear CGAL community
I am struggling with memory leaks when doing some simple manipulations of the geomtric locations of the vertices of a Polyhedron_3 when using the EPECK kernel."""
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: -CGAL_IA_MUL(-1.1, 10.1) != CGAL_IA_MUL(1.1, 10.1)
File: /home/benjamik/software/CGAL-4.8-beta1/local/include/CGAL/Interval_nt.h
Line: 209
Explanation: Wrong rounding: did you forget the -frounding-math option if you use GCC (or -fp-model strict for Intel)?
#include <CGAL/Exact_predicates_exact_constructions_kernel.h> #include <CGAL/Polyhedron_3.h> #include <CGAL/centroid.h> #include <string> #include <fstream> //---------------------------------------------------------------------------- template<typename Polyhedron> static void smooth_simple(Polyhedron& p, int iterations) //---------------------------------------------------------------------------- { typedef typename Polyhedron::Traits::Point_3 Point_3; typedef typename Polyhedron::Traits::Vector_3 Vector_3; typedef typename Polyhedron::Vertex_handle Vertex_handle; typedef typename Polyhedron::Halfedge_around_vertex_const_circulator HV_const_circulator; assert(p.is_valid()); for (std::size_t iteration = 0; iteration < iterations; iteration++) { std::vector<std::pair<Vertex_handle, Point_3> > smoothed; std::cout << "Iteration " << iteration << std::endl; // Compute new location for (typename Polyhedron::Vertex_iterator vit = p.vertices_begin(); vit != p.vertices_end(); vit++) { std::vector<Point_3> neighbors; const HV_const_circulator h_start = vit->vertex_begin(); HV_const_circulator h_current = h_start; do { neighbors.push_back(h_current->opposite()->vertex()->point()); h_current++; } while (h_current != h_start); const Point_3 centroid = CGAL::centroid(neighbors.begin(), neighbors.end(), CGAL::Dimension_tag<0>()); smoothed.push_back(std::make_pair(Vertex_handle(vit), centroid)); } // Apply new locations for (typename std::vector<std::pair<Vertex_handle, Point_3> >::iterator it = smoothed.begin(); it != smoothed.end(); it++) { it->first->point() = it->second; } } } //---------------------------------------------------------------------------- int main(int argc, char** argv) //---------------------------------------------------------------------------- { typedef CGAL::Polyhedron_3<CGAL::Exact_predicates_exact_constructions_kernel> Polyhedron; Polyhedron p; { std::ifstream infile(argv[1]); infile >> p; } std::cout << "Num vertices of polyhedron: " << p.size_of_vertices() << std::endl; const std::size_t iterations = 5; smooth_simple(p, iterations); std::ofstream outfile("smoothed.off"); outfile << p; }
- [cgal-discuss] Memory leak when using Polyhedron_3<EPECK>, Benjamin Kehlet, 02/17/2016
- Re: [cgal-discuss] Memory leak when using Polyhedron_3<EPECK>, Marc Glisse, 02/17/2016
- Re: [cgal-discuss] Memory leak when using Polyhedron_3<EPECK>, Benjamin Kehlet, 02/18/2016
