Re: [cgal-discuss] Questions on architecture of CGAL with respect to adding a feature
- To:
- Subject: Re: [cgal-discuss] Questions on architecture of CGAL with respect to adding a feature
- Date: Fri, 26 Feb 2016 18:30:52 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:aKM6fhE3QEXQTmAkBuXp0p1GYnF86YWxBRYc798ds5kLTJ75rsqwAkXT6L1XgUPTWs2DsrQf27WQ7fyrADVIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/niKbsp9aKOk1hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv50IbKPhYq5tTaBEFC90dCcu9cjzvF/CSxGO7z0SSCINgx9QCk/E6h/9GZz+uy+/uutm0zSBJp7KSuU/Vj2mqqtqUxT1kzwvNjgj8WiRhNYjorhcpUePvZ1zQpTVY8mtPeB3cqLGNYcUXWNbV54MBwRcBZ+gZpQGSeEIa7UL57LhrkcD+EPtTTKnA/nin2dF
Oh I see. It's starting to make sense. Thank you all very much for your help. I think you have answered all my questions for now. If someone wants to add something to this discussion, feel free to do so.
2016-02-26 16:18 GMT-05:00 Marc Glisse <>:
On Fri, 26 Feb 2016, Frédérik Paradis wrote:
Try harder? That is the most natural way in CGAL. If you have trouble with
it, maybe you can ask here with specific code. Maybe there is a real
obstruction that prevents from using this solution here, but you would
likely be asked to explain it before integrating code that uses a different
strategy.
Actually, my problem is that the constructor of Sphere_d is not the same as
constructing a Circle_2. Sphere_d takes an iterator of Point_d whereas
Point_2 only takes three points or a center with a radius. Do you know how
I could work around that?
Your traits class would not only provide the type Sphere_d, it would also provide a functor Construct_sphere_d. In the adaptor for Kernel_d, that is already provided. In the adaptor for Kernel_2, you would need to implement the functor so it reads the first 3 values of the iterator and calls Construct_circle_2 on those.
Marc Glisse
- Re: [cgal-discuss] Questions on architecture of CGAL with respect to adding a feature, (continued)
- Re: [cgal-discuss] Questions on architecture of CGAL with respect to adding a feature, Frédérik Paradis, 02/26/2016
- Re: [cgal-discuss] Questions on architecture of CGAL with respect to adding a feature, Marc Glisse, 02/26/2016
- Re: [cgal-discuss] Questions on architecture of CGAL with respect to adding a feature, Andreas Fabri, 02/26/2016
- Re: [cgal-discuss] Questions on architecture of CGAL with respect to adding a feature, Frédérik Paradis, 02/27/2016
