- To:
- Subject: [cgal-discuss] How to fix shifted elements in multidomain mesh??
- Date: Mon, 29 Feb 2016 12:27:22 -0800 (PST)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Neutral ; spf=None
- Ironport-phdr: 9a23:PU9btBEiB2YPIzwg6ZwdMp1GYnF86YWxBRYc798ds5kLTJ75os6wAkXT6L1XgUPTWs2DsrQf27WQ7fCrADdcqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh7/0pc2YOl4UzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IZ4yhIfV9FOQQTG9+ayFmrPHs4BLMRA/K6noHWXgNiTJJBRLE5Vf0RMTfqCz/4+l6wzWTMdDtBeQ3Xi++5qt2Uzf5gScAMHgy92SB2Z84t75SvB/0/k83+IXTeozAb6Imcw==
Dear all,
I am using the available example of 3d labeled image to produce a 3D mesh
derived from a segmented medical image. However in the contacts between the
different domains there are some shifted elements and the partiotioning is
not "clean" as shown in the attached image. How would be possible to cope
with this problem? I tried applying some sizing fields in the mesh criteria
but they seem to not affect the result.
Thank you in advance for your help.
Best regards,
Konstantinos.
cgal.png <http://cgal-discuss.949826.n4.nabble.com/file/n4661657/cgal.png>
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/How-to-fix-shifted-elements-in-multidomain-mesh-tp4661657.html
- [cgal-discuss] How to fix shifted elements in multidomain mesh??, kostadus, 02/29/2016
