- To:
- Subject: Re: [cgal-discuss] Mesh utility
- Date: Thu, 03 Mar 2016 14:14:40 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:ozt+WxafRlXQo/HRdDZJ0Rj/LSx+4OfEezUN459isYplN5qZpcq+bnLW6fgltlLVR4KTs6sC0LqJ9f+8EjBaqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh7/0pMGYP18ArQH+SI0xBS3+lR/WuMgSjNkqAYcK4TyNnEF1ff9Lz3hjP1OZkkW0zM6x+Jl+73YY4Kp5pIYTGZn9Kq83RLgdADU9OH0u/+XqswPCRE2B/CgySGITx1BzDgLM9w37U5G5lizgt+1hkGm1MMrzQKwuSBqr5LtsUg6pwm9TLDo+6mDQlop1iIpUpRugo1p0xIuCM9LdD+Z3Yq6IJYBSfmFGRMsEDyE=
There are several package you can use but none of them will solve
the problem out of the box, you'll need to code a few things.
Some packages than might be worth look at:
http://doc.cgal.org/latest/Kernel_23/classCGAL_1_1Exact__predicates__inexact__constructions__kernel.html (kernel providing exact predicates)
http://doc.cgal.org/latest/Kernel_23/group__collinear__grp.html#Index_anchor_415
http://doc.cgal.org/latest/Polygon_mesh_processing/
http://doc.cgal.org/latest/Periodic_2_triangulation_2/ (to detect points close to each other)
Sebastien.
On 03/03/2016 01:01 PM, elect wrote:
Hi guys,
I'd need a mesh tool that allows me:
to generate indices from a given triangle list
cleaning any incomplete, degenerate or multiple triangle/vertices
optimize the mesh reducing the triangle number by merging close vertices
Does Cgal include all of these?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Mesh-utility-tp4661671.html
- [cgal-discuss] Mesh utility, elect, 03/03/2016
- Re: [cgal-discuss] Mesh utility, Sebastien Loriot (GeometryFactory), 03/03/2016
