cgal-discuss - Re: [cgal-discuss] how to mesh medical image with multiple domains with features ??
  • To:
  • Subject: Re: [cgal-discuss] how to mesh medical image with multiple domains with features ??
  • Date: Fri, 11 Mar 2016 14:55:49 +0000
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:JWWA5xIlO/J15QZjtNmcpTZWNBhigK39O0sv0rFitYgUI/vxwZ3uMQTl6Ol3ixeRBMOAu60C27ud7f+ocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC0ILnhqvspNX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86FpyshbTK+vf7gkVacKS3M9ImUt7YvqswPCRE2B/DwHQ2AOm11JBQbCqxr1V5O0virhvfdmw3qmOpj9QrkwHDij9Kx2UwTAiSEdNjd//nuEpNZ3ifdjKR67rh1wizWcS4aTPvpj++uJZdQRQmxLXttQfyNEC4K4KYAICrxSbq5js4Dhqg5W/lOFDg62Cba3xw==
Hi Konstantinos,
Here's the code I used on my last project: https://bitbucket.org/poconbhui/cgalmeshing/src/eb3b0e5bc396e61c8c88833b8c221de882744d4a/src/make_smooth_polyhedron_from_discrete_image.h?at=master&fileviewer=file-view-default . It's a bit gross because it was only intended for quick use on one project.
The gist of the surface point extraction is to loop through the voxels, and of any of the neighbouring voxels have a different value, create a point on that interface.
The rest of it basically follows http://doc.cgal.org/latest/Surface_reconstruction_points_3/
Regards,
Paddy
On Tue, Mar 8, 2016 at 10:14 AM, Konstantinos Mountris <> wrote:
Greeting Padraig,
thank you for the tips! I have already done the first part of what you
suggest and I am stuck in the extraction of the surface points, i don't know
actually how i could do that, If you have any example code it would be of
great help. My image is a segmentation meaning that the different domains
have the same values of voxels in their whole domain with different values
only in the structures interfaces. If i could extract the surface points
which will be in this case the interface i will be able to do what i am
trying following the second example you posted I guess.
Once again thank you very much for the help!!
Best regards,
Konstantinos.
View this message in context: http://cgal-discuss.949826.n4.nabble.com/how-to-mesh-medical-image-with-multiple-domains-with-features-tp4661320p4661683.html
