cgal-discuss - Re: [cgal-discuss] Segmentation fault in example mesh_3D_image_variable_size.cpp
  • To:
  • Subject: Re: [cgal-discuss] Segmentation fault in example mesh_3D_image_variable_size.cpp
  • Date: Mon, 21 Mar 2016 07:00:55 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23:sDxfNBHHyWPLkpX2uhw4YJ1GYnF86YWxBRYc798ds5kLTJ75osiwAkXT6L1XgUPTWs2DsrQf27qQ6virBjFIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/nh6bro9aMPk1hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv50IbaKvdKsxSflUDS8tLnsuzMztrxjKCwWVtVUGVWBDuxxEGQXM91nUV53rs2Ouv+xxwiSTJov4RLouWByt4qBuRQPymSkOPCI+6nCRgct12vEI6Cm9rgByltaHKLqeM+BzK/vQ
Dear Danyang,
You should give more context, in order
to give you a reasonable answer.
In which directory did you execute it?
Did you pass it a file with data?
best,
andreas
On 20/03/2016 05:51, Danyang Su wrote:
Dear All,
I could compile the example mesh_3D_image_variable_size.cpp successfully
but got "Segmentation fault" when run it. Anything wrong with the code
or my installation?
Thanks,
Danyang
