cgal-discuss - Re: [cgal-discuss] Inset and offset of General_polygon_set_2 with circle arcs
  • To:
  • Subject: Re: [cgal-discuss] Inset and offset of General_polygon_set_2 with circle arcs
  • Date: Thu, 31 Mar 2016 14:26:34 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:LhwmLhI3ypJZ5ncr7NmcpTZWNBhigK39O0sv0rFitYgULv3xwZ3uMQTl6Ol3ixeRBMOAu6IC0LKd6PmocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC34Lsj6vpotX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqrze+E0TKdTES89G2Ez/szi8xfZHiWV4X5Jan8fjgtVGAiN1AvzWJ7v+n/irONhyTSIMOX5SLk1XXKp6KI9G0ygszsOKzNsqDKfscd3lq8O+B8=
Dear Monique,
It has been a long time, hope things are going well there. I have a slight problem that I am running into while trying to install CGAL 4.7 with Qt5 on the latest OSX El capitan. I registered myself with the CGAL discuss forum, but can’t seem to be able to post my query there. It would be great if you could help me get in touch with the relevant person, or give me a clue who to contact please.
Look forward to hearing from you,
pratyush
On 31 Mar 2016, at 08:08, Efi Fogel <> wrote:
What you describe may end up with a generalized polygon that have consecutive arcs. Representing the vertices requires a higher order algebraic number.
Hi,
A quick comment only on this specific aspect. Intersecting two circles should not require higher degree than intersecting a circle and a line. In both cases, it is degree 2.
Best,
Monique Teillaud
http://www.loria.fr/~teillaud/
INRIA Nancy - Grand Est, LORIA
Institut National de Recherche en Informatique et Automatique
