cgal-discuss - [cgal-discuss] Segmentation fault when determine if a point is inside a polyhedron
  • To:
  • Subject: [cgal-discuss] Segmentation fault when determine if a point is inside a polyhedron
  • Date: Mon, 4 Apr 2016 09:31:54 -0700
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:7HNk8RfdAvYal4Bg/sAx7P1dlGMj4u6mDksu8pMizoh2WeGdxc65bB7h7PlgxGXEQZ/co6odzbGG4+a7BidRvt6oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDivcaMKFQXzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IAu3GePEzQrVcSTgnKGso/9bDtB/ZTALJ6GFPfH8Rl09kCg7U5Rf1Fqzs+n/2v+xs0S+Ve9brZb8xUDWmqaxsTUm72288Kzcl/TSP2YRLh6VBrUf5qg==
Dear All,
I want to check if a point is inside a polyhedron by the example Polygon_mesh_processing/point_inside_example.cpp
http://doc.cgal.org/latest/Polygon_mesh_processing/Polygon_mesh_processing_2point_inside_example_8cpp-example.html
The actual code section used in my program is as follows
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef K::Point_3 Point3d;
    for (subdomainIterator=subdomains.begin();
            subdomainIterator!=subdomains.end();++subdomainIterator){
        CGAL::Side_of_triangle_mesh<Polyhedron, K> inside(subdomainIterator->polyHedron());
        std::cout << "Number of vertices in polyhedron " << subdomainIterator->polyHedron().size_of_vertices() << endl;
        std::cout << "Number of facets in polyhedron " << subdomainIterator->polyHedron().size_of_facets() << endl;
        std::cout << "Number of halfedges in polyhedron " << subdomainIterator->polyHedron().size_of_halfedges() << endl;
        std::cout << "is polyhedron closed " << subdomainIterator->polyHedron().is_closed() << endl;
        std::cout << "is polyhedron pure triangle " << subdomainIterator->polyHedron().is_pure_triangle() << endl;
        std::cout << "is polyhedron pure quadrilaterals " << subdomainIterator->polyHedron().is_pure_quad() << endl;
        for (int iz=0; iz<zdim; iz++){
            for (int iy=0; iy<ydim; iy++){
                for (int ix=0; ix<xdim; ix++){
                    int idx = iz*xdim*ydim + iy*xdim + ix;
                    double x = ix*dxmin + xcoord;
                    double y = iy*dymin + ycoord;
                    double z = iz*dzmin + zcoord;
                    Point3d pt(x,y,z);
                    CGAL::Bounded_side res = inside(pt);
                    if (res == CGAL::ON_BOUNDED_SIDE){
                        std::cout << "idx " << idx << std::endl;
                        data[idx] = subdomainIterator->DomainLabel();
When run the program, I get Segmentation fault at the line CGAL::Bounded_side res = inside(pt). The output of the polyhedron is as follows? Would anyone tell me what's wrong in my code?
Number of vertices in polyhedron 7
Number of facets in polyhedron 10
Number of halfedges in polyhedron 30
is polyhedron closed 1
is polyhedron pure triangle 1
is polyhedron pure quadrilaterals 0
Segmentation fault (From CGAL::Bounded_side res = inside(pt))
Thanks and Regards,
Danyang
