cgal-discuss - Re: [cgal-discuss] CGAL 4.8 Released, Computational Geometry Algorithms Library
  • To:
  • Subject: Re: [cgal-discuss] CGAL 4.8 Released, Computational Geometry Algorithms Library
  • Date: Fri, 8 Apr 2016 17:22:22 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:ost6rh1CkHut3+OssmDT+DRfVm0co7zxezQtwd8ZsegSL/ad9pjvdHbS+e9qxAeQG96Lu7QY1qGG7+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6CyZjqnLDus7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Lod8JtLXqz+Oqg5VrdFFy8OMmYv5cStuwOQYxGI4y4+VWwdkhtNSzLI7Rr6U5O55in9v+F92SzcJ8D3RrA5XRyt6rctRBK+23RPDCIw7GyC0p84t6lcuh/0/xE=
On 04/08/2016 03:11 PM, Laurent Rineau (CGAL/GeometryFactory) wrote:
> The CGAL Open Source Project is pleased to announce the release 4.8
> of CGAL, the Computational Geometry Algorithms Library.
Debian packages for CGAL 4.8 are now available as well. Simply add
deb http://debian.cgal.org jessie main
deb-src http://debian.cgal.org jessie main
deb http://debian.cgal.org stretch main
deb-src http://debian.cgal.org stretch main
to /etc/apt/sources.list (you only need the pair of lines corresponding
to the release you are using). For sid, packages should be available
from the official Debian repository in a few days. The packages are called
libcgal11v5, libcgal-dev, libcgal-qt5-11, libcgal-qt5-dev, libcgal-demo, and
libcgal-ipelets.
In case you want to download the packages manually, have a look at
http://debian.cgal.org/pool/main/c/cgal/ .
See also http://www.cgal.org/FAQ.html#debian_packages .
Joachim
