- To:
- Subject: Re: [cgal-discuss] some further questions on convex hull
- Date: Mon, 11 Apr 2016 17:13:13 +0300
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:mCg2lhWVvgEUsb2kr1Mp0P1WmPnV8LGtZVwlr6E/grcLSJyIuqrYZhCGt8tkgFKBZ4jH8fUM07OQ6PCwHzBRqsvR+Fk5M7VyFDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3CwN5K6zPF5LIiIzvjqbpq82VP1QD2Wr1SIgxBSv1hD2ZjtMRj4pmJ/R54TryiVwMRd5rw3h1L0mYhRf265T41pdi9yNNp6BprJYYAu2pN5g/GLdXBTBjP2Eu79DwrjHCSxGO7z0SSDY4iB1NVjDf5Q3rQ4zx+hPgv+x0xmHOJdf/UaEpSzmK4KJiSRuugyACYW1quFrLg9B92foI6CmqoAZyltbZ
i am getting segmentation fault 11 on mac os…apparently that has something to do with the limits of stack size…but i am not sure how to overcome this..
On 07 Apr 2016, at 16:06, Pratyush Pranav <> wrote:Hi Monique,thanks for the mail. What you suggest sounds good below. Actually, outputting the convex hull as a polyhedron_3 would have made my life much simple. But i think there is a problem. I have additional information stored on the vertices of the triangulation. I guess when I output the convex hull as a polyhedron, i lose this additional information on the vertices?I would “guess” the opposite, but in general I don’t trust guesses… I trust the manual better, and/or results of experiments.While going through the manual, I ahvent encountered the possibility of deriving polyhedron_3 from vertex_with_info_3. As far as I understand, it is only possible to derive the triangulation class from the base class of vertex with info. Any additional cues would be helpful.I guess i could circumvent this problem if I can also inherit the polyhedron from the vertex_base_with_if_3 class ( the name of the class is not accurate probably, i am spewing it out of my mind). Do you think it is possible to inherit poly from vertex with info? I am sorry, it has been many years since i touched CGAL, and i am on a bit of shaky ground here.Alternatively, if this is not possible,to be checkedI guess I can work with the original triangulation by restricting myself to the simplifies on the convex hull only. I think, for this i need to devise a function that checks if a particular simplex is on the convex hull or not. I write below my idea of how to check if a particular simplex is on the hull.— for a vertex it is trivial, because by design they are al on the surface of the sphere (or do i need additional checks?)you can check if it is incident to the infinite vertexcan a vertex itself be incident to the infinite vertex? i "guess" again it has to be through a cell or a facet or an edge, isnt it? i wonder what i am missing here.I should have written adjacent, instead of incident.I maybe wrong, but i was not able to find if it is possible to directly access the incident cells to a facet. hence i was going through the route of the "checking the edges of the facets". could you please confirm if it is indeed a possiblitiy to access the cells incident to a facet directly?How can you manage to access a facet without knowing at least one of its incident cells?--Monique Teillaud
http://www.loria.fr/~teillaud/
INRIA Nancy - Grand Est, LORIA
Institut National de Recherche en Informatique et Automatique
- Re: [cgal-discuss] some further questions on convex hull, (continued)
- Re: [cgal-discuss] some further questions on convex hull, Pádraig Ó Conbhuí, 04/14/2016
- Re: [cgal-discuss] some further questions on convex hull, Pratyush Pranav, 04/15/2016
- Re: [cgal-discuss] some further questions on convex hull, Pádraig Ó Conbhuí, 04/15/2016
- Re: [cgal-discuss] some further questions on convex hull, Monique Teillaud, 04/14/2016
- Re: [cgal-discuss] some further questions on convex hull, Monique Teillaud, 04/15/2016
