- To:
- Subject: Re: [cgal-discuss] some further questions on convex hull
- Date: Thu, 14 Apr 2016 12:19:24 +0200
On 14 Apr 2016, at 10:10, Pratyush Pranav <> wrote:
by the way, is it true that a simplex that belongs to convex hull may actually not be a part of the triangulation?
also, more importantly, when i output the infinite vertex it gives me the coordinates as (0,0,0).
i faintly remember reading in the coal manuals that for points on sphere, there is an insertion of a dummy point at (0,0,0)…
How can the algorithm know in advance that all points will be co-spherical? I imagine that you are making a confusion with the following: when you know in advance that your points are co-spherical, a common advice is to insert an additional point inside the ball that they form, in order to avoid having only degeneracies in your set of points.
so now, i convert to convex hull, and write it to a polyhedron_3. by the way, i think i have my answer. the halfedges are unique to a facet from what it looks like on the polyhedron documentation.
Monique Teillaud
http://www.loria.fr/~teillaud/
INRIA Nancy - Grand Est, LORIA
Institut National de Recherche en Informatique et Automatique
- Re: [cgal-discuss] some further questions on convex hull, (continued)
- Re: [cgal-discuss] some further questions on convex hull, Monique Teillaud, 04/11/2016
- Re: [cgal-discuss] some further questions on convex hull, Pratyush Pranav, 04/13/2016
- Re: [cgal-discuss] some further questions on convex hull, Monique Teillaud, 04/14/2016
- Re: [cgal-discuss] some further questions on convex hull, Pratyush Pranav, 04/14/2016
- Re: [cgal-discuss] some further questions on convex hull, Sebastien Loriot (GeometryFactory), 04/14/2016
- Re: [cgal-discuss] some further questions on convex hull, Pádraig Ó Conbhuí, 04/14/2016
- Re: [cgal-discuss] some further questions on convex hull, Pratyush Pranav, 04/15/2016
- Re: [cgal-discuss] some further questions on convex hull, Pádraig Ó Conbhuí, 04/15/2016
- Re: [cgal-discuss] some further questions on convex hull, Monique Teillaud, 04/15/2016
