Re: [cgal-discuss] Why is my OFF file producing segmentation fault for polyhedron generation ?
- To:
- Subject: Re: [cgal-discuss] Why is my OFF file producing segmentation fault for polyhedron generation ?
- Date: Thu, 14 Apr 2016 13:49:43 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:zepvIBCofFbPSaiUljpiUyQJP3N1i/DPJgcQr6AfoPdwSP/7oMbcNUDSrc9gkEXOFd2CrakU26yL7eu7AiQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTnkb3ssMaIKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46FppIZ9V77ndfE4UaBAF2ZhdHsk4dXi8xjFVwqGoHUGFX4HlwJBRAnD4ha9VZj4tm72t/F2xTKBbvHxGLs7UDDn46ZwQwLzkw8GMSQ4+SfZkJ9elqVe9TunqwZyypWcToifLvs2KqrbcckXTHEHUM9bTS1pDY67aoYTFfsPNO1EqJPs4VAJqE3tVkGXGOrzx2oQ1TfN1qog3rF5HA==
Are you both sure to use the same releases of CGAL?
andreas
On 14/04/2016 13:48, Timothée Nicolas wrote:
Thank you for your answer.
So you say you were able to produce a valid out.mesh file with the .off
file I suggested ?
I just checked on my Ubuntu computer, and it does the same as this
afternoon at work on a Mac OS X. The error message here is
Erreur de segmentation (core dumped)
If I remember correctly, on the mac, it was something like
Segmentation fault:11
I have added the verbose line you sent me, and it does not tell me
anything else...
Timothée
2016-04-14 19:45 GMT+09:00 Jane Tournois
<mailto:>>:
Hi Timothee,
I could not reproduce your seg fault.
You can try to add the following macro definition on the very first
line of your cpp file :
#define CGAL_MESH_3_VERBOSE
and then post the execution log?
This could help you or us find the error.
Also, you mention an "error message". What does it say ?
Best,
Jane.
Jane Tournois, PhD
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
Le 14/04/2016 10:18, Timothée Nicolas a écrit :
Dear all,
I am trying to produce a 3D tetrahedral mesh from a boundary
surface mesh. I
figured that the easiest way to do this was to use a .OFF file of my
boundary, which does not seem too difficult to produce, and feed
it directly
to this example program
http://doc.cgal.org/latest/Mesh_3/Mesh_3_2mesh_polyhedral_domain_8cpp-example.html
Before taking on my actual boundary surface mesh, I need to
understand
exactly what I am doing, so I tried replacing the file
elephant.off with the
following simple .off file representing a pyramid
OFF
5 6 0
0.0 0.0 0.0
1.0 0.0 0.0
1.0 1.0 0.0
0.0 1.0 0.0
0.5 0.5 1.0
3 2 1 0
3 3 2 0
3 0 1 4
3 1 2 4
3 2 3 4
3 3 0 4
Unfortunately this produces a segmentation fault when making the
mesh. I
have no idea what causes it to malfunction. Anyone has a clue ?
I have also
tried with a simple tetrahedron or a cube with each face cut
into two
triangles, same error message.
Best
Timothee
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] Why is my OFF file producing segmentation fault for polyhedron generation ?, Timothée Nicolas, 04/14/2016
- Re: [cgal-discuss] Why is my OFF file producing segmentation fault for polyhedron generation ?, Jane Tournois, 04/14/2016
- Re: [cgal-discuss] Why is my OFF file producing segmentation fault for polyhedron generation ?, Timothée Nicolas, 04/14/2016
- Re: [cgal-discuss] Why is my OFF file producing segmentation fault for polyhedron generation ?, Andreas Fabri, 04/14/2016
