- To:
- Subject: [cgal-discuss] Failing to run CGAL
- Date: Fri, 15 Apr 2016 23:14:54 +0300
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:re+IxBxqt6olnuHXCy+O+j09IxM/srCxBDY+r6Qd0e8WIJqq85mqBkHD//Il1AaPBtWLra8bwLCJ6ujJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6CyZnonLrtotX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqrze+E0TKdTES89G2Ez/szi8xfZHiWV4X5Jc2oQmwEAKRLMHhAIXZbq+n/7uex0w2+QJ8TtTKs3WC+K4KJiSRuugyACYW1quFrLg9B92foI6CmqoAZyltbZ
I cannot compile CGAL using application, because it Can't find definition. Do you have any idea what could be wrong
/usr/include/CGAL/Constrained_Delaunay_triangulation_face_base_2.h:42: error: no type named 'Point_2' in 'class CGAL::Triangulation_vertex_base_2<CGAL::Epick>'
typedef typename Kernel::Point_2 Point;
- [cgal-discuss] Failing to run CGAL, Ignas Brašiškis, 04/15/2016
- Re: [cgal-discuss] Failing to run CGAL, Sebastien Loriot (GeometryFactory), 04/18/2016
- Re: [cgal-discuss] Failing to run CGAL, Ignas Brašiškis, 04/19/2016
- Re: [cgal-discuss] Failing to run CGAL, Sebastien Loriot (GeometryFactory), 04/19/2016
