- To:
- Subject: Re: [cgal-discuss] Data structure performance differences
- Date: Mon, 18 Apr 2016 21:20:14 +0300
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:a6Qc+RfVxq2zBtYxB3K1xK+elGMj4u6mDksu8pMizoh2WeGdxc6zZB7h7PlgxGXEQZ/co6odzbGG4+a+AydZu8zJmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbviq9uNOU4R3mD1SIgxBSv1hD2ZjtMRj4pmJ/R54TryiVwMRd5rw3h1L0mYhRf265T41pdi9yNNp6BprJYYAu2pN5k+VqFSWTQ6L3gutoqsrgjGVQLJ530GU2xQnAAPGBnA9Bi9X5H/tWzxueN5nSWbJsbrVqtnZTP35KhiTFrkiTwMKiUi2GDRkM15yqxB8zy7oBkq7oDVKK+SO/d6NvfQc9IUQmVMWu5eUiVABsW3aI5ZXLlJBvpRs4So/whGlhC5HwT5XO4=
Hi Kevin,
Inserting curves into an arrangement can be done either incrementally or in an aggregate fashion.
The incremental insertion is based on the zone framework and the aggregate insertion is based on the plane-sweep framework. There are several references to these algorithmic frameworks out there.Inserting curves into an arrangement can be done either incrementally or in an aggregate fashion.
Inserting n curves into an arrangement using the zone framework takes O(n^2) time, while inserting n curves into an arrangement using the plane-sweep framework takes O((k+n) log(n)) time, where k is the number of intersections between the n curves.
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
_/
On Mon, Apr 18, 2016 at 7:59 PM, KHartmann <> wrote:
Hi,
I have used both the 2D Triangulation and 2D Arrangement classes.
I have found that adding constraint edges to a Triangulation is
extremely fast regardless of how large the Triangulation grows.
But I have found, when adding edges to an Arrangement, the insertion
time gets longer and longer as the Arrangement grows. (I am only adding
straight line segments and x_monotone arcs).
Is this to be expected? What is the order of these two Algorithms?
It seems that adding a constraint edge to a Triangulation might be
constant time O(1). But perhaps adding edges to an Arrangement is somewhat
more expensive O( n-squared )?
Are there any tricks that I might use to speed up insertion time into
an Arrangement? Right now I'm adding edges one at a time in arbitrary
order.
Thanks,
Kevin
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Data-structure-performance-differences-tp4661842.html
- [cgal-discuss] Data structure performance differences, KHartmann, 04/18/2016
- Re: [cgal-discuss] Data structure performance differences, Efi Fogel, 04/18/2016
- Re: [cgal-discuss] Data structure performance differences, KHartmann, 04/18/2016
