cgal-discuss - RE: [cgal-discuss] mesh generation from levelset and preserving some things
  • To: "" <>
  • Subject: RE: [cgal-discuss] mesh generation from levelset and preserving some things
  • Date: Thu, 21 Apr 2016 15:18:12 +0000
  • Accept-language: en-US
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23:YPUwFx0I/y+GyfBbsmDT+DRfVm0co7zxezQtwd8ZsekVLvad9pjvdHbS+e9qxAeQG96Lu7Qa26GG7ejJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6CyZrnnLDss7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Loc8dVdW/D6Y7ggVu4fSy83Nng8osztrxjKCwWVoWANV30f1RtODQ+C5x7zWtL9szDxq/FmixWdaIf9QrkwHDij9Kx2UwTAiSEdNjd//nudwph7g6tf5R6gvBdi2JX8YYePNfM4cLmLLv0AQm8UFOx2bQBsP8uSYo8OF+dJfd1xgbPUgRpE5U+wCA2tHO6pwDhSinLr9bYz3f4oF0fIxlpzTJo1rH3IoYCtZ+8pWuevwfyQwA==
Thanks, but can you develop a little bit more your answer. Can I convert
(read from file) my mesh into a Cgal mesh object?.
Or maybe I can use the Line Features to impose the edges and the points on
the interface between domain to be meshed (levelset) and my mesh so I get a
compatible triangulation?
Felipe
-----Message d'origine-----
De :
[mailto:]
De la part de Laurent Rineau (CGAL/GeometryFactory)
Envoyé : jeudi 21 avril 2016 16:08
À :
Objet : Re: [cgal-discuss] mesh generation from levelset and preserving some
things
Le Thursday 21 April 2016 12:15:51 BORDEU Felipe a écrit :
> Hello,
> I'm trying to generate a 3D mesh (using
> make_mesh_3<http://doc.cgal.org/latest/Mesh_3/group__PkgMesh__3Functio
> ns.ht
> ml#ga9159a9a2d11e027577fd8212956896f7>) and to preserve some features
> . My input information are:
> A Levelset image (double float).
> And for some cases I want to preserve:
> Point Features,
> Line Features ,
> Surface Features,
> Volume Features.
> I know how to produce a 3D mesh from an image (levelset from disk) and
> preserve point and lines (I have a working app using [1]) . But I want
> to preserve also some surface and volumes mesh. For example if a have
> a tomography image and a mesh for a prosthesis that I want to insert
> in the mesh.
> Any idea if I can do this with CGAL. (I'm using CGAL 4.8)
Hi,
If the mesh you want to preserve was already created using CGAL, that might
be feasible. Otherwise, if the mesh you want to preserve does not have the
properties of CGAL meshes (Delaunay or "regular" criteria), there is no
chance that the mesh can be preserved as it is.
Laurent Rineau, PhD
" Ce courriel et les documents qui lui sont joints peuvent contenir des
informations confidentielles, être soumis aux règlementations relatives au
contrôle des exportations ou ayant un caractère privé. S'ils ne vous sont pas
destinés, nous vous signalons qu'il est strictement interdit de les
divulguer, de les reproduire ou d'en utiliser de quelque manière que ce soit
le contenu. Toute exportation ou réexportation non autorisée est interdite Si
ce message vous a été transmis par erreur, merci d'en informer l'expéditeur
et de supprimer immédiatement de votre système informatique ce courriel ainsi
que tous les documents qui y sont attachés."
" This e-mail and any attached documents may contain confidential or
proprietary information and may be subject to export control laws and
regulations. If you are not the intended recipient, you are notified that any
dissemination, copying of this e-mail and any attachments thereto or use of
their contents by any means whatsoever is strictly prohibited. Unauthorized
export or re-export is prohibited. If you have received this e-mail in error,
please advise the sender immediately and delete this e-mail and all attached
documents from your computer system."
