cgal-discuss - Re: [cgal-discuss] mesh generation from levelset and preserving some things
  • To:
  • Subject: Re: [cgal-discuss] mesh generation from levelset and preserving some things
  • Date: Fri, 22 Apr 2016 10:37:39 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:hsH/mhK/VqR3XD6fU9mcpTZWNBhigK39O0sv0rFitYgULfzxwZ3uMQTl6Ol3ixeRBMOAu6IC1LKd6/qocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC34Loj6vqodX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqrze+E0TKdTES89G2Ez/szi8xfZHiWV4X5JGEEfjwBFBRSN1hD8U57s+mvRmcNZnwaXOsj7Uaoldz2p86BxWV6iwHMDPiMj/WfLzNZxiq9SvTqqqBV7hYnOb9fGZ7JFYqrBcIZCFiJ6VcFLWnkZDw==
Le Thursday 21 April 2016 15:18:12 BORDEU Felipe a écrit :
> Thanks, but can you develop a little bit more your answer. Can I convert
> (read from file) my mesh into a Cgal mesh object?.
The mesh produces by CGAL needs geometrical properties, mainly the Delaunay
criterion. If the mesh you want to preserve does not have that property, the
only hope is to remesh it using the CGAL 3D mesh generator, and then there
will be hope that you can write a custom mesh domain class, that allows to
mix
you mesh with the levelset.
> Or maybe I can use the Line Features to impose the edges and the points on
> the interface between domain to be meshed (levelset) and my mesh so I get
> a compatible triangulation?
If you do that, the lines, corresponding to the edges of the input mesh, will
be remeshed, and even then there is no guarantee that the facets of the input
mesh can be represented by union of Delaunay facets.
Laurent Rineau, PhD
