- To: cgal-discuss <>
- Subject: [cgal-discuss] Duplicated halfedges and faces after remeshing
- Date: Wed, 27 Apr 2016 12:52:27 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:+TtUDh/1CDyNt/9uRHKM819IXTAuvvDOBiVQ1KB91uwcTK2v8tzYMVDF4r011RmSDdWdu6sP0bGempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXsq3G/pQQfBg/4fVIsYL+lSsiC1o/tjKibwN76XUZhvHKFe7R8LRG7/036l/I9ps9cEJs30QbDuXBSeu5blitCLFOXmAvgtI/rpMYwu3cYh/V0/MFJVeD2fr8zUKdDRGAtPGkxocHqrhLeVhCn530GU2xQnAAeUCbf6xSvdJr3sCL/t+w1+ySaOcDqBeQ+VDKg5qJqSzfziSIaMzd/9maB2Z84t75SvB/0/083+IXTeozAbPc=
Dear CGAL team
Thank you very much for your work with the Surface_mesh and Polygon_mesh processing_packages, and in particular the newly added implementation of isotropic remeshing. It is much appreciated!Line 532: 3 281 122 126
Line 827: 3 294 126 122
So the faces in line 320 and 530 seems to be the same but with opposite orientation. The faces in line 320 and 532 share a halfedge from v122 to v126 and the faces in line 530 and 827 shared a halfedge from v126 to v122.
I hope someone can take a look an comment if I'm doing something wrong, the input can not be handled by the function or if this is a problem in CGAL.
Thanks in advance!
#include <CGAL/Exact_predicates_inexact_constructions_kernel.h> #include <CGAL/Surface_mesh.h> #include <CGAL/boost/graph/graph_traits_Surface_mesh.h> #include <CGAL/Polygon_mesh_processing/remesh.h> #include <CGAL/Polygon_mesh_processing/border.h> #include <boost/function_output_iterator.hpp> #include <fstream> #include <vector> typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel; typedef Kernel::FT FT; typedef Kernel::Point_3 Point; typedef Kernel::Vector_3 Vector; typedef CGAL::Surface_mesh<Point> Surface_mesh; typedef Surface_mesh::Vertex_index Vertex_index; typedef Surface_mesh::Face_index Face_index; typedef Surface_mesh::Edge_index Edge_index; typedef Surface_mesh::Halfedge_index Halfedge_index; typedef boost::graph_traits<Surface_mesh>::face_descriptor face_descriptor; typedef boost::graph_traits<Surface_mesh>::edge_descriptor edge_descriptor; int main(int argc, char** argv) { namespace Parameters = CGAL::Polygon_mesh_processing::parameters; Surface_mesh m; { std::ifstream infile(argv[1]); infile >> m; } std::cout << "Num vertices: " << m.number_of_vertices() << std::endl; std::cout << "Num faces: " << m.number_of_faces() << std::endl; //---------------- Protect egdes sharper than 60 degrees ------------------ const double cos_tolerance = .5; Surface_mesh::Property_map<edge_descriptor, bool> edge_constrained_map = m.add_property_map<edge_descriptor, bool>("e:is_constrained", false).first; std::size_t num_protected = 0; double longest_protected = 0.; Surface_mesh::Property_map<face_descriptor, Vector> fnormals = m.add_property_map<face_descriptor, Vector>("f:normals", CGAL::NULL_VECTOR).first; CGAL::Polygon_mesh_processing::compute_face_normals(m, fnormals); for (Edge_index e : m.edges()) { Halfedge_index h = e.halfedge(); Face_index f1 = m.face(h); Face_index f2 = m.face(m.opposite(h)); const Vector& n1 = fnormals[f1]; const Vector& n2 = fnormals[f2]; if (n1*n2 < cos_tolerance) { longest_protected = std::max(longest_protected, Vector(m.point(m.source(h)), m.point(m.target(h))).squared_length()); edge_constrained_map[e] = true; num_protected++; } } m.remove_property_map(fnormals); std::cout << "Num protected: " << num_protected << std::endl; std::cout << "Longest protected: " << sqrt(longest_protected) << std::endl; //------------------------- Remeshing ---------------------------------- CGAL::Polygon_mesh_processing::isotropic_remeshing(faces(m), .03, m, Parameters::edge_is_constrained_map(edge_constrained_map) .protect_constraints(true) ); { std::ofstream ofile("remeshed.off"); ofile << m; } }
remeshed.off
Description: model/geomview-off
cylinder.off
- [cgal-discuss] Duplicated halfedges and faces after remeshing, Benjamin Kehlet, 04/27/2016
- Re: [cgal-discuss] Duplicated halfedges and faces after remeshing, Jane Tournois, 04/29/2016
