- To:
- Subject: [cgal-discuss] CDTP mesh - getting all edges
- Date: Tue, 3 May 2016 01:44:50 -0700 (PDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Neutral ; spf=None
- Ironport-phdr: 9a23:p8Mn/hT5Kc/JFSQaY7d6Vh5KAdpsv+yvbD5Q0YIujvd0So/mwa64YByN2/xhgRfzUJnB7Loc0qyN4/CmCDdLuMzJmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbviq9uCOE4R3nKUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGZPTJPppCOUARHR9azh0t4XXskzIQgKLo3cdSW4LiQFgAg7f7Ri8UI2inDH9s79W3zOQPMC+GbszQz6j4o9uQR7sgiAXcTkj/zeE2YRLkKtHrUf49FREyInObdTObKJz
Hi,
I have created a mesh by adding the outlines of some convex polygons to a
CDTP
[CGAL::Constrained_triangulation_plus_2<Constrained_Delaunay_triangulation_2>]
and refining it
[CGAL::Delaunay_mesher_2(my_cdtp).refine_mesh()].
Now I would like to draw the mesh with OpenGL, so I have to iterate over all
the edges in the CDTP.
Using the Subconstraint_iterator and even a inner loop using the
Vertices_in_constraint_iterator just gives me the constraint borders.
How can I iterate over all the edges of the mesh?
Kind regards,
Corbie
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CDTP-mesh-getting-all-edges-tp4661883.html
- [cgal-discuss] CDTP mesh - getting all edges, Corbie, 05/03/2016
- Re: [cgal-discuss] CDTP mesh - getting all edges, Sebastien Loriot (GeometryFactory), 05/04/2016
- Re: [cgal-discuss] CDTP mesh - getting all edges, Corbie, 05/05/2016
- Re: [cgal-discuss] CDTP mesh - getting all edges, Sebastien Loriot (GeometryFactory), 05/10/2016
