cgal-discuss - Re: [cgal-discuss] Using ranges in point set processing?
  • To:
  • Subject: Re: [cgal-discuss] Using ranges in point set processing?
  • Date: Wed, 4 May 2016 08:41:38 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23:AJh69hK5bN765zaUrtmcpTZWNBhigK39O0sv0rFitYgUL/TxwZ3uMQTl6Ol3ixeRBMOAu6MC07Od6vi8EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ35Xxj7n5osWPKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46FppIZ8VvDxcK08CLBZFz87KHsd5cvxtBCFQxHcyGEbVzAtkx9PBUDq7QvzQ5v2rmOuret43y/cMszsRK04XiiK4KpsTRL0kjYJPjUl93vGzMd3ifQI81qauxVjztuMM8muP/1kc/aFcA==
Le 04/05/2016 01:25, Marc Glisse a écrit :
On Tue, 3 May 2016, Andreas Fabri wrote:
A related question is if the CGAL Range concept
http://doc.cgal.org/latest/Circulator/classRange.html
is the way it should be, or if it has design flaws.
The future seems to be
https://github.com/ericniebler/stl2/raw/master/D4569.pdf
The CGAL concept doesn't look fundamentally incompatible with SizedRange...
Thanks for the document. Indeed, it seems that removing the requirement for a size() operator would make the CGAL Range concept would make it compatible (or as you pointed, turning it into a SizedRange concept).
Something already available and based on free functions (instead of methods, similarly to the "get" mechanism that we already use in CGAL) is the Boost Range: http://www.boost.org/doc/libs/1_39_0/libs/range/doc/boost_range.html
It seems to be even more generic (accepting also pairs of iterators –which would make the transition from pairs of iterators to range really straightfoward– and built-in arrays).
Simon Giraudot, PhD
R&D Engineer
GeometryFactory - http://geometryfactory.com/
