- To:
- Subject: [cgal-discuss] Polyhedron - load normals from obj
- Date: Wed, 11 May 2016 08:35:15 -0700 (PDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Neutral ; spf=None
- Ironport-phdr: 9a23:LTMK6hTgDMMNZw+aQvVFXFftJdpsv+yvbD5Q0YIujvd0So/mwa64YByN2/xhgRfzUJnB7Loc0qyN4/GmADJLsM/JmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbviqtuKPU4Z3XKUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGZPTJPppCOUARHR9azh0t4XXskzIQgKLo3cdSW4LiQFgAg7f7Ri8UI2inDH9s793wiCEOpStBeQ+Qz286P4wYATlmiEOMngy4jeE2YRLkKtHrUf49FREyInObdTObKJz
I am using OBJ loader with this:
where T is CGAL::Polyhedron_3::HalfedgeDS
This works... however, I want to manually add normals to the vertices, but
there is no B.add_normal()... how to do this ?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Polyhedron-load-normals-from-obj-tp4661902.html
- [cgal-discuss] Polyhedron - load normals from obj, bravo13, 05/11/2016
