cgal-discuss - Re: [cgal-discuss] polyhedron with user defined extra information on the vertices
  • To:
  • Subject: Re: [cgal-discuss] polyhedron with user defined extra information on the vertices
  • Date: Wed, 18 May 2016 14:20:05 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:dFM4NBImhh2MGpcff9mcpTZWNBhigK39O0sv0rFitYgVK/vxwZ3uMQTl6Ol3ixeRBMOAu6MC0LKd7/uocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC3oLsj6vuoNX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86FpyshbTK+vf7gkVacKS3M9ImUt7YvqswPCRE2B/DwHQ2AOm11JBQbCqxr1V5O0virhvfdmw3qmOpj9QrkwHDij9Kx2UwTAiSEdNjd//nuEpNZ3ifcRmx+rrgdjwoPSKKWSLvt5YuudUt4dQGddRNd/XiddBZmtLsFHW/EFOvxZqJW7ol8moh63BA3qD+TqnGwbzkTq1LE3hrxyWTrN2xYtSooD
Your vertex class is missing a point data member.
template <class Refs, class Traits>
struct My_vertex :
public CGAL::HalfedgeDS_vertex_base<Refs, CGAL::Tag_true, typename Traits::Point_3> {
typedef typename Traits::Point_3 Point;
typedef CGAL::HalfedgeDS_vertex_base<Refs, CGAL::Tag_true, Point> Base;
double value;
long index;
My_vertex() : Base(){}
My_vertex(const Point& p) : Base(p) {}
Sebastien.
On 05/18/2016 10:54 AM, Pratyush Pranav wrote:
Hi Sebastian,
Thanks for pointing out the relevant material.
Now, I try to write a basic code (a modification of one of the examples to
have colour on the faces of the tetrahedron from the CGAL documentation), to
be able to have some of my own items on the vertices, and also have access to
point() on the vertex (this is what is giving me problems). Could you please
help me with where I am going wrong? Below is the code.
pratyush
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Polyhedron_3.h>
// A face type with a color member variable.
typedef CGAL::Simple_cartesian<double> Kernel;
struct My_vertex : public CGAL::HalfedgeDS_vertex_base<Refs> {
double value;
long index;
// An items type using my face.
struct My_items : public CGAL::Polyhedron_items_3 {
struct Vertex_wrapper {
typedef My_vertex<Refs,Traits> Vertex;
typedef Kernel::Point_3 Point_3;
typedef CGAL::Polyhedron_3<Kernel,My_items> Polyhedron;
typedef Polyhedron::Halfedge_handle Halfedge_handle;
typedef Polyhedron::Vertex_handle Vertex_handle;
int main() {
Point_3 p( 0.0, 0.0, 0.0);
Point_3 q( 1.0, 0.0, 0.0);
Point_3 r( 0.0, 1.0, 0.0);
Point_3 s( 0.0, 0.0, 1.0);
Polyhedron P;
P.make_tetrahedron(p,q,r,s);
Vertex_handle v = P.vertices_begin();
//v->value = 3.14;
v->index = 1;
std::cerr<<v->point()<<" "<<v->index<<std::endl;
return 0;
On 17 May 2016, at 10:03, Sebastien Loriot (GeometryFactory)
wrote:
It is possible using a custom items traits (second template parameter).
The concept is documented here:
http://doc.cgal.org/latest/Polyhedron/classPolyhedronItems__3.html
For an example see how ids are added to simplices in
CGAL/Polyhedron_items_with_id_3.h
Note that using the class Surface_mesh would allow you to do property
assignment at run-time.
http://doc.cgal.org/latest/Surface_mesh/
Best,
Sebastien.
On 05/15/2016 02:43 PM, Pratyush Pranav wrote:
Hi,
I would like to know if it is possible to derive a polyhedron_3 in such a way
that i can store a couple of extra information on the vertices (specifically
each vertex should have two additional variables associated with it, one of a
double type, and another one of long or int type).
any leads would be great! thanks in advance!
pratyush
