Re: [cgal-discuss] Is there an implementation of the tangential Delaunay complex?
- To:
- Subject: Re: [cgal-discuss] Is there an implementation of the tangential Delaunay complex?
- Date: Wed, 18 May 2016 15:07:32 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:ZqyOQBYZ5st05I0U1v7l/tH/LSx+4OfEezUN459isYplN5qZpciybnLW6fgltlLVR4KTs6sC0LqH9fu4EjFeqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh7H0oMWYPlsArQH+SI0xBS3+lR/WuMgSjNkqAYcK4TyNnEF1ff9Lz3hjP1OZkkW0zM6x+Jl+73YY4Kp5pIYTGZn9Kq83RLgdADU9OH0u/+XqswPCRE2B/CgySGITxzFMgg3I6g3NfJ70sy2y4uF51SyXO9GwT7kxWDLk971sYBDtgSYDcTU+9TeE2YRLkKtHrUf59FREyInObdTNOQ==
Hi Samuel,
I'm working on an implementation, but it's not released yet. I'm going to contact you by e-mail to see how you and your colleague can test it.
Regards,
Clément.
On Wed, May 18, 2016 at 1:16 PM, Samuel Hornus <> wrote:
Hi,A colleague of mine is looking for an implementation (even experimental) of the Tangential Delaunay complex algorithmintroduced by J.-D. Boissonnat and A. Ghosh in"Manifold reconstruction using tangential Delaunay complexes". Discrete & Computational Geometry, 51(1), 2014.Would anyone know of such an implementation?Thank you,Samuel
- [cgal-discuss] Is there an implementation of the tangential Delaunay complex?, Samuel Hornus, 05/18/2016
- Re: [cgal-discuss] Is there an implementation of the tangential Delaunay complex?, Clément Jamin, 05/18/2016
