cgal-discuss - [cgal-discuss] Re-triangulate points (in CGAL) every step + Segmentation fault (core dump)
  • To: "" <>
  • Subject: [cgal-discuss] Re-triangulate points (in CGAL) every step + Segmentation fault (core dump)
  • Date: Tue, 31 May 2016 15:31:17 +0000 (UTC)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:ntDifBEqmv8GuSMWII/5Hp1GYnF86YWxBRYc798ds5kLTJ74pM2wAkXT6L1XgUPTWs2DsrQf27uQ7v2rCTxIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/nhqbvptaDM01hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv/RLT6myU60kQPRRCjMjOmQkrI2x7FiQBTeIszEXXWwS1xZJGAPY9wrSX5HrsyK8uPA3kH2RMsTyCLw1Qj+/9LxDSRnyiS5BOSRvo1vakshhsKUOuBu7pgd2i5TdYIScMvs2KrnUfeQCTHBpT89RUCsHCYS5OdghFe0EaP5RtYjmrhMUpBu7DA+tTLf1wz9/nnbs9bwz0+MmVwrB2VpzTJo1rH3IoYCtZ+8pWuevwfySlDg=
Hi,
I want to simulate a system of particles for N steps. In every step, periodic triangulation of these points is constructed. In every step coordinates of particles change, So, I need to remove (or delete) triangulation of the previous step and make a new one.
In step 0 every thing is good, but in the next step, when triangulation is going to be remade from modified points, SEGMENTATION FAULT appears.
Then according to suggestion of someone from Stackoverflow.com, I saved the new points (points updated in step 0) in a file with double precision and tried to construct a triangulation from these points,  in this case too, the SEG-FAULT appears.
using namespace std;
//******************CGAL_prerequisite************************/
typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel;
typedef CGAL::Periodic_2_triangulation_traits_2<Kernel> Gt;
typedef CGAL::Triangulation_vertex_base_with_info_2<unsigned int, Gt> Vb;
typedef CGAL::Periodic_2_triangulation_face_base_2<Gt> Fb;
typedef CGAL::Triangulation_data_structure_2<Vb, Fb> Tds;
typedef CGAL::Periodic_2_Delaunay_triangulation_2<Gt, Tds> Triangulation;
typedef Triangulation::Point Point;
typedef Triangulation::Edge_iterator Edge_iterator;
typedef Triangulation::Vertex_handle Vertex_handle;
typedef Triangulation::Vertex_circulator Vertex_circulator;
typedef Triangulation::Iso_rectangle Iso_rectangle;
typedef Triangulation::Vertex_iterator Vi;
typedef std::vector<std::pair<Point, unsigned> > Vector;
/*********************Simulation_parameters*****************/
const int N = 16;
double L = 4;        //linear size of the square
double S = 0.5;         //0.5
double dt = 1.0;
int N_step = 100;
ofstream output("traj_2D.xyz");
int main(){
Iso_rectangle domain(0,0,L,L);
Vector points;
vector<vector<double> > dir;//an array for 2D velocities of each particle
dir.resize(N);
for(int i=0; i<N; i++){dir[i].resize(2);}
vector<vector<double> > pos;//an array for 2D initial positions
pos.resize(N);
for(int i=0; i<N; i++){pos[i].resize(2);}
/*****initialize_positions*****/
//some part of the code
/*****initialize_velocities*****/
  for (int i = 0; i < N; i++)
       points.push_back(make_pair(Point(pos[i][0], pos[i][1]), i));
for(int istep = 0; istep < N_step; istep++)
      Triangulation T(points.begin(), points.end(), domain);
      //update positions and apply periodic boundary conditons
        for (int i = 0; i < N; i++) {
             points[i].first = Point(points[i].first.x()+S*dir[i][0]*dt , points[i].first.y()+S*dir[i][1]*dt);
            // use periodic boundary conditions
            if (points[i].first.x() < 0)
                points[i].first=Point(points[i].first.x()+L, points[i].first.y());
            if (points[i].first.y() < 0)
                points[i].first=Point(points[i].first.x(), points[i].first.y()+L);
            if (points[i].first.x() > L)
                points[i].first=Point(points[i].first.x()-L, points[i].first.y());
            if (points[i].first.y() > L)
          //write the updated positions to a file
output.precision(17);
  for(int s = 0; s < N; s++){ output<<points[s].first.x()<<" "<<points[s].first.y()<<" "<<"0.0"<<endl;} T.clear();//I don't know, whether this is necessary or not.
ifstream in("traj_2D.xyz"); istream_iterator<Point> begin(in);
 istream_iterator<Point> end;
  Triangulation TRI;
 TRI.insert(begin, end);
} return 0;}
Any suggestion would be appreciated.
Parisa
  • [cgal-discuss] Re-triangulate points (in CGAL) every step + Segmentation fault (core dump), parisa rahmani, 05/31/2016
