- To:
- Subject: Re: [cgal-discuss] CGAL Poisson surface reconstruction compilation error
- Date: Fri, 3 Jun 2016 12:21:23 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:DpWG3BdKSm2uZtd/p/QfaYjJlGMj4u6mDksu8pMizoh2WeGdxc68bB7h7PlgxGXEQZ/co6odzbGG4ua+AidavN6oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDjvcOIKF8VzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IZ4yhIP99FeAQTGl+cjN92Mq+vhbKSU6D52AXT34NuhtOGQnMqh/gDbnrtS6vn+xxwiSTJoXYRLouWHz25qFnUhLhk2EJPjQj8UnYh8t1gb5BsRyorAB42Z+Sa4aQYqktNpjBdM8XEDISFv1aUDZMV97kYg==
Hello,
please upgrade CGAL. Also what does your code look like (put a
self contained example in a gist on github), and write what version
of VC++ do you use.
best,
andreas
On 03/06/2016 11:29, neiji93 wrote:
I have a compilation error with visual studio for CGAL Poisson surface
reconstruction. I paste the source code and make the correct template
structures for the MeshBuilder class parameters.
But the compiler says as an error : error C2666:
'CGAL::internal::Static_filters_predicates::Orientation_3<K_base>::operator
()' : 2 surfcharges have similar conversions
d:\cgal-4.3\cgal-4.3\include\cgal\triangulation_3.h 265 1
PostProcess_2012
I don't know if this is due that I use CGAL 4.3
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-Poisson-surface-reconstruction-compilation-error-tp4661972.html
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] CGAL Poisson surface reconstruction compilation error, neiji93, 06/03/2016
- Re: [cgal-discuss] CGAL Poisson surface reconstruction compilation error, Andreas Fabri, 06/03/2016
- Re: [cgal-discuss] CGAL Poisson surface reconstruction compilation error, neiji93, 06/03/2016
