- To:
- Subject: Re: [cgal-discuss] Lloyd optimization and center of mass
- Date: Fri, 10 Jun 2016 15:58:40 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:/AyynRdVZzzI08sfJ+4SoYJllGMj4u6mDksu8pMizoh2WeGdxc69ZB7h7PlgxGXEQZ/co6odzbGG4ua/Biddvd6oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDjvcKMKFgUzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IAu3GePEzQrVcSTgnKGso/9bDtB/ZTALJ6GFPfH8Rl08CJwHY9hz8Qt/Lsy33v/c1mAK1FOmxYr0zXDm+9bZFQRT0jz0WdnRxpGXel9Z9ir4duhOnqhVi64XbaYXTM+BxKPCONegGTHZMC54CHxdKBZmxOtMC
Le Friday 10 June 2016 14:49:31 Yann GAVET a écrit :
> Hello all,
> I basically want to implement a code for stipple algorithm
> (https://mrl.nyu.edu/~ajsecord/stipples.html), which uses a centroidal
> voronoi diagram weighted by a gray level image (the center of the
> Voronoi cells move to the center of mass instead of the centroid).
> What would be the best way to code this algorithm with CGAL, efficiently
> ? is their a way to transform Lloyd mesh optimization
> (CGAL::lloyd_optimize_mesh_2) for using the center of mass given by an
> exterior constraint on each cell (here, given by the pixels of the image
> laying in the cell).
Have a look at the function `lloyd_optimize_mesh_2_impl` from
`<CGAL/lloyd_optimize_mesh_2.h>`. It starts with:
typedef Mesh_2::Mesh_sizing_field<CDT> Sizing;
typedef Mesh_2::Lloyd_move_2<CDT, Sizing> Mv;
typedef Mesh_2::Mesh_global_optimizer_2<CDT, Mv> Optimizer;
Optimizer lloyd(cdt,
convergence_ratio,
freeze_bound);
If you replace `Mesh_2::Lloyd_move_2` by a modification of it, it can do what
you want. You will need to copy and paste `<CGAL/Mesh_2/Lloyd_move_2.h>` and
then modify the function `operator()` that computes the move. As for the
modification of that function `operator()`, you are on your own.
Laurent Rineau, PhD
- [cgal-discuss] Lloyd optimization and center of mass, Yann GAVET, 06/10/2016
- Re: [cgal-discuss] Lloyd optimization and center of mass, Laurent Rineau (CGAL/GeometryFactory), 06/10/2016
