cgal-discuss - Re: [cgal-discuss] Limiting the maximum length of an edge in a Delaunay triangulation
  • To:
  • Subject: Re: [cgal-discuss] Limiting the maximum length of an edge in a Delaunay triangulation
  • Date: Fri, 10 Jun 2016 18:00:04 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:yJjJDxYy20fRokgFSNngrNn/LSx+4OfEezUN459isYplN5qZpcu6bnLW6fgltlLVR4KTs6sC0LqH9f+/Ej1Zqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh7H0pMKYMlwArQH+SI0xBS3+lR/WuMgSjNkqAYcK4TyNnEF1ff9Lz3hjP1OZkkW0zM6x+Jl+73YY4Kp5pIYTGZn9Kq83RLgdADU9OH0u/+XqswPCRE2B/CgySGITx1BsChXf4RfmFq3wtCbzq6I98wazGYrZQLcxVCi4/oliQwPvkjZGfXZt9GjKkMF2kORBoRSsrgFXyIHdZMeSLvUoLfCVRs8TWWcUBpUZbCdGGI7pN4Y=
Le Friday 10 June 2016 17:28:46 Pol Monsó Purtí a écrit :
> Hello Laurent, thank you for your interest,
> *All* the faces are said to be outside the domain, not only those long
> faces. Otherwise I'd be done by checking wether it is in or out. Should I
> check that my cdt constitutes indeed a *planar straight line graph *? Is it
> possible it doesn't at all?
I suggest you insert in the CDT a closed polygon with four vertices, a "box",
that contains all the other ones. That way, you will be sure that everything
is inside the domain bounded by that box.
Laurent Rineau, PhD
