cgal-discuss - Re: [cgal-discuss] Lloyd optimization on a 2d CDT issue
  • To:
  • Subject: Re: [cgal-discuss] Lloyd optimization on a 2d CDT issue
  • Date: Fri, 17 Jun 2016 15:16:59 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:CasG9RT6l26C8SDG06kRTsQK1dpsv+yvbD5Q0YIujvd0So/mwa64YhCN2/xhgRfzUJnB7Loc0qyN4/GmCDRLv8/JmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbviqtuCO04W3XKUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGfayQ6NtRrNRCHEqMns++dbwnRjFVwqGoHUGAUsMlR8dSTPI5hjhQpb8tGPesfB83zXSfeL7SrU5RS6zwa5gVBjymWZNf2oi9GbNi8tsyqdfiB2krh17hYXTZdfGZ7JFYqrBcIZCFiJ6VcFLWnkZDw==
Your example compiles fine with CGAL 4.7, CGAL 4.8 and the master branch using g++5.3.
What version of CGAL and gcc are you using?
Sebastien.
On 06/16/2016 06:15 PM, ballbugsbunny wrote:
Hi Laurent,
thanks a lot for your help and guidance on reporting..
This is the gist with a minimal example:
https://gist.github.com/fbalaban/f60f70066fb99101aad181c0eecd6cd4
FYI I'm in the Kubuntu Linux distro 14.04, having installed CGAL by the
package manager through apt-get install libcgal-dev and compiled the project
using a simple gcc compiler.
Thanks a lot,
Fotis
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Lloyd-optimization-on-a-2d-CDT-issue-tp4661994p4662001.html
