- To:
- Subject: Re: [cgal-discuss] Finding adjacent segments from SDF Mesh Segmentation
- Date: Fri, 24 Jun 2016 21:31:06 +0530
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:nRdYoB/wEs0/bv9uRHKM819IXTAuvvDOBiVQ1KB92uscTK2v8tzYMVDF4r011RmSDN2ds6IP2rOempujcFRI2YyGvnEGfc4EfD4+ouJSoTYdBtWYA1bwNv/gYn9yNs1DUFh44yPzahANS47AblHf6ke/8SQVUk2mc1EkfqKtSsWD1oye7KObw9XreQJGhT6wM/tZDS6dikHvjPQQmpZoMa0ryxHE8TNicuVSwn50dxrIx06vrpT4wZh47i4Fu+4979USFuLhbqEgRPpZCi4nOiY7/orwpBzbREyO4HUbFW4Zmx4NDwne5wzhRcTNtX7xueN5nSWbJsbrVqscWDK47q4tRgW7pj0AMmsC7WLXkMVyxJlaph2h70hkwojbYMeOKfl+ZKrfVdwfTGtFGM1WUnoSUcuHc4ITAr9Zbq5jpI7nqg5WoA==
Yes, that could be one approach, your reply has bolstered my thought , Thanks :)
The facet iteration is not like hopping between neighboring facets ....
On Fri, Jun 24, 2016 at 9:02 PM, Sebastien Loriot (GeometryFactory) <> wrote:
Iterate over edges and connect if the two faces incident
do not belong to the same segment then put a 1 in
the matrix.
Sebastien.--
On 06/24/2016 05:00 PM, Sukhraj Singh wrote:
Hello,
I am trying to create an adjacency matrix for the segments.(undirected)
I tried following code snippet, (the code isnt perfect though)
The segment_ids ,contains the ids of the segments, its populated in the
Surface Mesh Segmentation Plugin.
int current_segment = -1;
int prev_segment = -1;
int adjmat[10][10] = {0};
for(Polyhedron::Facet_iterator facet_it = polyhedron->facets_begin();
facet_it != polyhedron->facets_end(); ++facet_it)
current_segment = segment_ids[facet_it];
if(current_segment != prev_segment)
//std::cout << std::endl;
//std::cout << " segment: "<< prev_segment << " and " << " segment: " << current_segment;
//std::cout << " Are adjacent" << std::endl;
adjmat[current_segment][prev_segment] = 1;
prev_segment = current_segment;
The output of adjmat is
0 1 1 1 1 1 0 0 0 1
1 0 1 1 1 1 0 0 0 0
1 1 0 1 1 1 0 0 0 0
1 1 1 0 1 1 0 0 0 0
1 1 1 1 0 1 0 0 0 0
1 1 1 1 1 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
No. of segments were six, that's why > 6,6 elements are ale zeros
Looks like the facet iteration is not "from one facet to neighboring
facet" ? I assumed, I could record that particular jump from a facet to
other that leads to segment id change , and make those segments as adjacent.
Thanks to check the fallacy in my approach.
Sukhraj Singh
Sukhraj Singh
- [cgal-discuss] Finding adjacent segments from SDF Mesh Segmentation, Sukhraj Singh, 06/24/2016
- Re: [cgal-discuss] Finding adjacent segments from SDF Mesh Segmentation, Sebastien Loriot (GeometryFactory), 06/24/2016
- Re: [cgal-discuss] Finding adjacent segments from SDF Mesh Segmentation, Sukhraj Singh, 06/24/2016
