cgal-discuss - Re: [cgal-discuss] Which algorithm should I use to find the nearest neighbors?
  • To:
  • Subject: Re: [cgal-discuss] Which algorithm should I use to find the nearest neighbors?
  • Date: Mon, 27 Jun 2016 16:38:02 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:bfRHChJN4ewOBYHHyNmcpTZWNBhigK39O0sv0rFitYgUL/TxwZ3uMQTl6Ol3ixeRBMOAuqoC0rOd7PyocFdDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXsq3G/pQQfBg/4fVIsYL+kQsiL1o/oi6ibwN76W01wnj2zYLd/fl2djD76kY0ou7ZkMbs70RDTo3FFKKx8zGJsIk+PzV6nvp/jtM0rzyMFsP0o84tMUL7xYr8jZb1eFjUvdW4vt+PxshyWBzCC7HIHTmQblFJsBBLE6w2yHrj8tS73qvBs9iCRIcrsXPF+EWC566BxSRj0ziIDHzE8+WDTzMd3ifQI81qauxVjztuMM8muP/1kc/aFcA==
The orthogonal search is the fastest one:
http://doc.cgal.org/latest/Spatial_searching/classCGAL_1_1Orthogonal__k__neighbor__search.html
You can start from this example:
http://doc.cgal.org/latest/Spatial_searching/Spatial_searching_2searching_surface_mesh_vertices_8cpp-example.html
Sebastien.
On 06/27/2016 03:44 PM, Michael Klatt wrote:
Dear all,
I have found your very interesting package "dD Spatial Searching". I want to
use it to find nearest neighbors. However, I am unsure which of the
algorithms that you implemented is the most efficient in my setting. May I
ask for your advice?
Given a fine mesh P of points (with some larger holes in it) and another
(much) sparser set of points Q in d dimensions, I want to find for each
point in P the nearest neighbor in Q as well as the corresponding Euclidean
distance.
Here is a simple example:
<http://cgal-discuss.949826.n4.nabble.com/file/n4662013/point-sets.png>
Can you advise me which algorithm I should use?
To which of your examples in the manual does this correspond?
Thank you very much!
Best regards,
Michael
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Which-algorithm-should-I-use-to-find-the-nearest-neighbors-tp4662013.html
