cgal-discuss - Re: [cgal-discuss] Which algorithm should I use to find the nearest neighbors?
  • To:
  • Subject: Re: [cgal-discuss] Which algorithm should I use to find the nearest neighbors?
  • Date: Fri, 01 Jul 2016 07:32:29 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:bekfMBffX6ebNSFD/G5c8E45lGMj4u6mDksu8pMizoh2WeGdxc6/bB7h7PlgxGXEQZ/co6odzbGH6+a5CSdRsd6oizMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JXvkbnisMyDKyxzxxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Lod8JtLXqz+Oqg5VrdFFy8OMmYv5cStuwOQYxGI4y5WaWgcmwFUAgXDpDX9RJb2rmO6med63SSGJ9zYRLsoXi6zru0jHATsjz0GMCJ/9WX/hcl5jaYdqxWk8U8si7XIaZ2YYaItNpjWeskXEDJM
On 06/30/2016 10:05 PM, Michael Klatt wrote:
Dear Sebastien,
thank you very much for the fast answer and especially for pointing out the
example! That was very helpful.
Can I generalize my program to higher (or two) dimensions by using Point_d?
http://doc.cgal.org/latest/Kernel_d/classCGAL_1_1Point__d.html
Sure.
Sebastien.
Thank you very much!
Best regards,
Michael
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Which-algorithm-should-I-use-to-find-the-nearest-neighbors-tp4662013p4662019.html
  • Re: [cgal-discuss] Which algorithm should I use to find the nearest neighbors?, Sebastien Loriot (GeometryFactory), 07/01/2016
