Re: [cgal-discuss] adding additional variables in 3D triangulation data structure
- To:
- Subject: Re: [cgal-discuss] adding additional variables in 3D triangulation data structure
- Date: Sat, 16 Jul 2016 23:51:20 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:FXKgJhJCWhx82A3GmtmcpTZWNBhigK39O0sv0rFitYgVKv/xwZ3uMQTl6Ol3ixeRBMOAuqoC17ed6Pi4EUU7or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuS9aU05n8jLjqs7ToICxwzAKnZr1zKBjk5S7wjeIxxbVYF6Aq1xHSqWFJcekFjUlhJFaUggqurpzopM0roGxtvek8/ZtATbniZPZ/CqdJCSwvdWEz/szi8xfZChCe42MVFWQQnB0PCAfM6FT2X4z6rzDh5dZ6jSKVNMmzQbEvUim59I9qTgXpgWEJLW0X6mbS3+V2gLhWqQnpiRV12Y+cNIiTOOBzd7ibc9oQX2tpUctWUiFdGJKyZoATCPAQe+1fqt+u9BM1sRKiCFz0V6vUwThSiyqu0A==
Please have a look at the example in the manual:
http://doc.cgal.org/latest/Triangulation_3/index.html#Triangulation3secexamplescolor
On 16/07/2016 17:37, Tianyun Su wrote:
Hi Adam,
Thank you for your response and instruction. I have not use
Triangulation_vertex_base_with_info_3 or
Triangulation_cell_base_with_info_3 before. Can you give me a more
instruction about assigning and accessing the value of the added
unsigned integer variable?
Thanks again.
Tianyun
On Sat, Jul 16, 2016 at 7:31 AM, Adam Getchell
wrote:
Sorry, the rest of the header might be useful:
// CGAL headers
#include <CGAL/Triangulation_vertex_base_with_info_3.h>
#include <CGAL/Triangulation_cell_base_with_info_3.h>
#include <CGAL/Delaunay_triangulation_3.h>
using K = CGAL::Exact_predicates_inexact_constructions_kernel;
using Triangulation = CGAL::Triangulation_3<K>;
// Used so that each timeslice is assigned an integer
using Vb = CGAL::Triangulation_vertex_base_with_info_3<std::uintmax_t, K>;
// Used to mark cell type
using Cb = CGAL::Triangulation_cell_base_with_info_3<std::uintmax_t, K>;
// Parallel operations
#ifdef CGAL_LINKED_WITH_TBB
using Tds = CGAL::Triangulation_data_structure_3<Vb, Cb, CGAL::Parallel_tag>;
#else
using Tds = CGAL::Triangulation_data_structure_3<Vb, Cb>;
#endif
using Delaunay = CGAL::Delaunay_triangulation_3<K, Tds>;
using Cell_handle = Delaunay::Cell_handle;
using Vertex_handle = Delaunay::Vertex_handle;
using Locate_type = Delaunay::Locate_type;
using Point = Delaunay::Point;
Adam
Adam Getchell
about.me/adamgetchell
- [cgal-discuss] adding additional variables in 3D triangulation data structure, Tianyun Su, 07/15/2016
- Re: [cgal-discuss] adding additional variables in 3D triangulation data structure, Adam Getchell, 07/16/2016
- Re: [cgal-discuss] adding additional variables in 3D triangulation data structure, Tianyun Su, 07/16/2016
- Re: [cgal-discuss] adding additional variables in 3D triangulation data structure, Andreas Fabri, 07/16/2016
- Re: [cgal-discuss] adding additional variables in 3D triangulation data structure, Tianyun Su, 07/18/2016
