cgal-discuss - Re: [cgal-discuss] Delaunay Triangulation insertion
  • To:
  • Subject: Re: [cgal-discuss] Delaunay Triangulation insertion
  • Date: Wed, 20 Jul 2016 21:37:47 -0700 (PDT)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
  • Ironport-phdr: 9a23:D67C+h8J6w9slP9uRHKM819IXTAuvvDOBiVQ1KB90eMcTK2v8tzYMVDF4r011RmSDN2dtq4P2rOempujcFRI2YyGvnEGfc4EfD4+ouJSoTYdBtWYA1bwNv/gYn9yNs1DUFh44yPzahANS47AblHf6ke/8SQVUk2mc1EkfqKoRsWD1oye7KObw9XreQJGhT6wM/tZDS6dikHvjPQQmpZoMa0ryxHE8TNicuVSwn50dxrIx06vrpT4wJk2+CtZv7ct9tVLTL7hV6U+V71RSjo8YE4v48i+jQPKSwKRri8ESGwQmwQYAgne5zn1W57wtm3xse8ri3rSBtH/Ub1hAWfq1KxsUhK90Co=
gupta61 wrote
> If I have an existing Delaunay Triangulation from a bunch of points (call
> it T1), is there a way to insert a set of new points, either as a vector
> or one by one, without disturbing the connectivities of the finite cells
> of the existing Triangulation T1.
You may specify T1 as the constraints to be preserved and try constructing a
Constrained Delaunay triangulation like here
<http://wias-berlin.de/software/tetgen/1.5/doc/manual/manual002.html#sec7>
(see section 1.2.4). However, it will not preserve Delaunay property(but
constrained Delaunay) and it may result in addition of new points called the
/steiner points/.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Delaunay-Triangulation-insertion-tp4662083p4662085.html
